楼主: mojave
nginx静态规则这样添加为何不行,该如何改
 楼主| 发表于 2009-10-13 00:16:17 | 只看该作者
worker_processes 1;
error_log  /home/logs/nginx_error.log  crit;
pid        /usr/local/nginx/logs/nginx.pid;
#Specifies the value for maximum file descriptors that can be opened by this process.
worker_rlimit_nofile 51200;
events
                use epoll;
                worker_connections 51200;
http
                include       mime.types;
                default_type  application/octet-stream;
                #charse  gb2312;
                server_names_hash_bucket_size 128;
                client_header_buffer_size 32k;
                large_client_header_buffers 4 32k;
                client_max_body_size 8m;
                sendfile on;
                tcp_nopush     on;
                keepalive_timeout 60;
                tcp_nodelay on;
                fastcgi_connect_timeout 300;
                fastcgi_send_timeout 300;
                fastcgi_read_timeout 300;
                fastcgi_buffer_size 64k;
                fastcgi_buffers 4 64k;
                fastcgi_busy_buffers_size 128k;
                fastcgi_temp_file_write_size 128k;
                gzip on;
                gzip_min_length  1k;
                gzip_buffers     4 16k;
                gzip_http_version 1.0;
                gzip_comp_level 2;
                gzip_types       text/plain application/x-javascript text/css application/xml;
                gzip_vary on;
                #limit_zone  crawler  $binary_remote_addr  10m;
server
                listen       80;
                server_name www.moltown.com moltown.com;
                index index.html index.htm index.php;
                root  /home/www;
                #limit_conn   crawler  20;
                #location /status {
                #stub_status        on;
                #access_log        off;
location /bbs {
            rewrite ^/archiver/((fid|tid)-[\w\-]+\.html)$ /archiver/index.php?$1 last;
            rewrite ^/forum-([0-9]+)-([0-9]+)\.html$ /forumdisplay.php?fid=$1&page=$2 last;
            rewrite ^/thread-([0-9]+)-([0-9]+)-([0-9]+)\.html$ /viewthread.php?tid=$1&extra=page%3D$3&page=$2 last;
            rewrite ^/space-(username|uid)-(.+)\.html$ /space.php?$1=$2 last;
            rewrite ^/tag-(.+)\.html$ /tag.php?name=$1 last;
            break;
                location ~ .*\.(php|php5)?$
                                fastcgi_pass  unix:/tmp/php-cgi.sock;
                                #fastcgi_pass  127.0.0.1:9000;
                                fastcgi_index index.php;
                                include fcgi.conf;
                location ~ .*\.(gif|jpg|jpeg|png|bmp|swf)$
                                expires      30d;
                location ~ .*\.(js|css)?$
                                expires      12h;
                log_format  access  '$remote_addr - $remote_user [$time_local] "$request" '
             '$status $body_bytes_sent "$http_referer" '
             '"$http_user_agent" $http_x_forwarded_for';
                access_log  /home/logs/access.log  access;
如上,去掉emlog那个rewrite,测试通过,kill -HUP `cat /usr/local/nginx/logs/nginx.pid`之后依然打不开....绝望了...看来是DZ7.1的原因
52#
发表于 2009-10-13 00:22:23 | 只看该作者
回复 51# 的帖子
可能是discuz 7.1的伪静态规则跟6.0不一样了吧。
53#
 楼主| 发表于 2009-10-13 00:25:26 | 只看该作者
回复 52# 的帖子
法科DZ,不过还是再次感谢,受教了
54#
发表于 2009-10-13 00:27:37 | 只看该作者
回复 53# 的帖子
GMT+8, 2026-4-19 01:13 , Processed in 0.067786 second(s), 9 queries , Gzip On, MemCache On.
