楼主: mojave
nginx静态规则这样添加为何不行,该如何改
发表于 2009-10-12 23:43:34 | 只看该作者
你第二段 就是 多了一个 }
32#
发表于 2009-10-12 23:45:08 | 只看该作者
回复 30# 的帖子
moltown.com/bbs和moltown.com/my可不是域名哦,你只要/home/www/绑定域名moltown.com就行了哈,后面的server段都可以删除掉,第一个server段写成
server
                listen       80;
                server_name www.moltown.com moltown.com;
                index index.html index.htm index.php;
                root  /home/www;
                #limit_conn   crawler  20;
                #location /status {
                #stub_status        on;
                #access_log        off;
location /bbs {
            rewrite ^/archiver/((fid|tid)-[\w\-]+\.html)$ /archiver/index.php?$1 last;
            rewrite ^/forum-([0-9]+)-([0-9]+)\.html$ /forumdisplay.php?fid=$1&page=$2 last;
            rewrite ^/thread-([0-9]+)-([0-9]+)-([0-9]+)\.html$ /viewthread.php?tid=$1&extra=page%3D$3&page=$2 last;
            rewrite ^/space-(username|uid)-(.+)\.html$ /space.php?$1=$2 last;
            rewrite ^/tag-(.+)\.html$ /tag.php?name=$1 last;
            break;
                location ~ .*\.(php|php5)?$
                                fastcgi_pass  unix:/tmp/php-cgi.sock;
                                #fastcgi_pass  127.0.0.1:9000;
                                fastcgi_index index.php;
                                include fcgi.conf;
                location ~ .*\.(gif|jpg|jpeg|png|bmp|swf)$
                                expires      30d;
                location ~ .*\.(js|css)?$
                                expires      12h;
                log_format  access  '$remote_addr - $remote_user [$time_local] "$request" '
             '$status $body_bytes_sent "$http_referer" '
             '"$http_user_agent" $http_x_forwarded_for';
                access_log  /home/logs/access.log  access;
然后后面的server段都可以删除了。
33#
发表于 2009-10-12 23:45:50 | 只看该作者
原帖由 mojave 于 2009-10-12 23:41 发表
/home/www/bbs    moltown.com/bbs
/home/www/my     moltown.com/my
日志是公用的吧/home/logs/access.log
server 放的是 域名
你要是 要 一个域名 后面 跟 目录的  bbs  和 my 的话 那就只用一个 server端了
34#
发表于 2009-10-12 23:48:37 | 只看该作者
user  www www;
worker_processes 1;
error_log  /home/logs/nginx_error.log  crit;
pid        /usr/local/nginx/logs/nginx.pid;
#Specifies the value for maximum file descriptors that can be opened by this process.
worker_rlimit_nofile 51200;
events
  use epoll;
  worker_connections 51200;
http
  include       mime.types;
  default_type  application/octet-stream;
  #charset  gb2312;
  server_names_hash_bucket_size 128;
  client_header_buffer_size 32k;
  large_client_header_buffers 4 32k;
  client_max_body_size 8m;
  sendfile on;
  tcp_nopush     on;
  keepalive_timeout 60;
  tcp_nodelay on;
  fastcgi_connect_timeout 300;
  fastcgi_send_timeout 300;
  fastcgi_read_timeout 300;
  fastcgi_buffer_size 64k;
  fastcgi_buffers 4 64k;
  fastcgi_busy_buffers_size 128k;
  fastcgi_temp_file_write_size 128k;
fastcgi_intercept_errors on;
  gzip on;
  gzip_min_length  1k;
  gzip_buffers     4 16k;
  gzip_http_version 1.0;
  gzip_comp_level 2;
  gzip_types       text/plain application/x-javascript text/css application/xml;
  gzip_vary on;
  #limit_zone  crawler  $binary_remote_addr  10m;
  server
    listen       80;
    server_name  moltown.com;
    root  /home/www;
location /bbs {
            break;
location /my {
if ($host != 'moltown.com/my' ) {
        rewrite  ^/(.*)$  http://moltown.com/my/$1  permanent;
        rewrite ^/(post|record|sort|author|page)-([0-9]+)\.html$ /index.php?$1=$2;
        rewrite ^/tag-(.+)\.html$ /index.php?tag=$1;
      include fcgi.conf;
    location ~ .*\.(gif|jpg|jpeg|png|bmp|swf|flv)$
      expires      30d;
      expires      12h;
35#
发表于 2009-10-12 23:49:42 | 只看该作者
回复 34# 的帖子
一直没弄明白 里面的
这段是用来干啥的?
36#
发表于 2009-10-12 23:52:40 | 只看该作者
应该是 一个 blog 的 rewrite 规则吧 呵呵
37#
发表于 2009-10-12 23:53:48 | 只看该作者
回复 36# 的帖子
哦了,楼主去试试吧
38#
发表于 2009-10-12 23:57:41 | 只看该作者
对了 楼主 哪些 rewrite 你最好 自己 重新 写下 我不知道 给你放的 对不对
39#
发表于 2009-10-12 23:58:19 | 只看该作者
回复 38# 的帖子
discuz那个是对的,其他未知。
40#
发表于 2009-10-13 00:01:09 | 只看该作者
回复 39# 的帖子
哦 呵呵
GMT+8, 2026-4-20 17:42 , Processed in 0.062755 second(s), 8 queries , Gzip On, MemCache On.
