查看: 7489|回复: 15
[疑问] 大家帮我PING下,我这很不稳定。。。
发表于 2009-10-10 12:25:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
66.172.38.80
谢谢了
Reply from 66.172.38.80: bytes=32 time=245ms TTL=52
Reply from 66.172.38.80: bytes=32 time=473ms TTL=52
Reply from 66.172.38.80: bytes=32 time=395ms TTL=52
Reply from 66.172.38.80: bytes=32 time=316ms TTL=52
发表于 2009-10-10 12:40:10 | 只看该作者
Reply from 66.172.38.80: bytes=32 time=217ms TTL=53
Reply from 66.172.38.80: bytes=32 time=214ms TTL=53
Reply from 66.172.38.80: bytes=32 time=215ms TTL=53
Reply from 66.172.38.80: bytes=32 time=213ms TTL=53
发表于 2009-10-10 12:41:30 | 只看该作者
C:\>ping 66.172.38.80
Pinging 66.172.38.80 with 32 bytes of data:
Reply from 66.172.38.80: bytes=32 time=185ms TTL=54
Reply from 66.172.38.80: bytes=32 time=186ms TTL=54
发表于 2009-10-10 12:46:23 | 只看该作者
C:\Documents and Settings\Administrator>ping 66.172.38.80 /t
Reply from 66.172.38.80: bytes=32 time=181ms TTL=53
Reply from 66.172.38.80: bytes=32 time=192ms TTL=53
Reply from 66.172.38.80: bytes=32 time=169ms TTL=53
Reply from 66.172.38.80: bytes=32 time=243ms TTL=53
Reply from 66.172.38.80: bytes=32 time=170ms TTL=53
Reply from 66.172.38.80: bytes=32 time=221ms TTL=53
Reply from 66.172.38.80: bytes=32 time=168ms TTL=53
Reply from 66.172.38.80: bytes=32 time=234ms TTL=53
Reply from 66.172.38.80: bytes=32 time=195ms TTL=53
发表于 2009-10-10 12:47:30 | 只看该作者
Reply from 66.172.38.80: bytes=32 time=195ms TTL=52
Reply from 66.172.38.80: bytes=32 time=193ms TTL=52
Reply from 66.172.38.80: bytes=32 time=191ms TTL=52
Reply from 66.172.38.80: bytes=32 time=192ms TTL=52
Reply from 66.172.38.80: bytes=32 time=190ms TTL=52
Reply from 66.172.38.80: bytes=32 time=194ms TTL=52
Ping statistics for 66.172.38.80:
    Packets: Sent = 15, Received = 15, Lost = 0 (0% loss),
    Minimum = 190ms, Maximum = 195ms, Average = 192ms
Pronethosting的主机?
发表于 2009-10-10 12:51:34 | 只看该作者
Cyberverse 数据中心的,满快哦 不知LZ是不是买的哪家的VPS
发表于 2009-10-10 12:54:35 | 只看该作者
回复 6# 的帖子
5楼回复底部。
发表于 2009-10-10 13:00:56 | 只看该作者
正在 Ping 66.172.38.80 具有 32 字节的数据:
来自 66.172.38.80 的回复: 字节=32 时间=242ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=264ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=296ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=106ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=137ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=54ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=77ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=100ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=122ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=144ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=65ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=88ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=111ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=133ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=91ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=109ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=132ms TTL=52
来自 66.172.38.80 的回复: 字节=32 时间=154ms TTL=52
发表于 2009-10-10 13:01:07 | 只看该作者
的确不稳定来着
发表于 2009-10-10 13:04:25 | 只看该作者
原帖由 cpuer 于 2009-10-10 12:54 发表
5楼回复底部。
这家服务器本月半价,貌似很强大。
我一直在想几个人如果合租两台不同地方的美国服务器(互为备份),性价比一定很高,就是比较麻烦 嘿嘿
GMT+8, 2026-4-20 07:25 , Processed in 0.061728 second(s), 10 queries , Gzip On, MemCache On.
