查看: 3020|回复: 9
RAK真奇怪
发表于 2018-7-12 15:37:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
自己一堆别人添加的iso,让加几个Debian和Fedora死活不愿意,怼一下又说可以协助安装,真迷,添加一个iso有多难
Yvonne Lu || Client
I see no Debian 9 stretch at available OS choice, then Ubuntu 18.04 LTS Bionic Beaver also no
So can U add latest server OS image or iso to SolusVM?
This is image of some latest OS
Ubuntu 18.04 Bionic Beaver
http://releases.ubuntu.com/18.04/ubuntu-18.04-live-server-amd64.iso
Debian 9.4 Stretch
https://cdimage.debian.org/debian-cd/current/amd64/iso-dvd/debian-9.4.0-amd64-DVD-1.iso
Fedora Server 28
https://download.fedoraproject.org/pub/fedora/linux/releases/28/Server/x86_64/iso/Fedora-Server-dvd-x86_64-28-1.1.iso
Fedora Server 27
https://download.fedoraproject.org/pub/fedora/linux/releases/27/Server/x86_64/iso/Fedora-Server-dvd-x86_64-27-1.6.iso
openSUSE Leap 15.0
https://download.opensuse.org/distribution/leap/15.0/iso/openSUSE-Leap-15.0-DVD-x86_64.iso
yuan yichao || Staff
Hello, I'm sorry that we can't use the mirror installation system you provided.
yichao
Tutorial & Guidance/资料指南:http://www.raksmart.com/Index/guide?l=zh-cn
投诉建议:feedback@raksmart.com
Yvonne Lu || Client
So Can you add them to CDROM list then I install manually for VPS?
Some system templates are too old, many are versions that have lost technical support or even stopped security update.
However, the risk of upgrading across major versions is high and there are great uncertainties.
Hello, this cannot be added for you.
yichao
Yvonne Lu || Client
Why there is lots of iso that latest Fedora,Ubuntu or Debian cannot be add FXXK
Hello, if you want to reinstall the system, we can operate it for you. What version of the system do you want to install?
yichao
发表于 2018-7-12 16:35:45 | 只看该作者
这家不是国人开的吗 ?
发表于 2018-7-12 16:28:59 来自手机 | 只看该作者
其实吧,他家可以直接说中文
 楼主| 发表于 2018-7-12 15:54:12 | 只看该作者
IDCexper 发表于 2018-7-12 15:47
上面显示的应该都是可以自动安装,你的需要手动安装,肯定是想让你用比较省事的啊 ...
我截图的是ISO,不是模板,本来就是通过vnc自己装的
 楼主| 发表于 2018-7-12 15:40:12 | 只看该作者
不知道故意怼他会不会愿意加进去
Yvonne Lu || Client
maybe Fedora Server 28 with GPT partition,LVM with xfs filesystem,It's best to use the host name (lyra) as the VG name
If you think this is more troublesome, the easiest way is to add iso directly to the CDROM, then we can install it ourselves.
Ubuntu 18.04 Server LTS is an alternate plan if there is a problem with stability or compatibility for Fedora 28
发表于 2018-7-12 15:42:50 | 只看该作者
发表于 2018-7-12 15:47:25 | 只看该作者
 楼主| 发表于 2018-7-12 16:03:11 | 只看该作者
If you add the ISO to the CDROM list, then I can install it myself through VNC without any assistance. This is actually the most convenient way, but I don't understand why you can't always add them,isos are official releases, I'm no way to add any malware to it.
To be honest, as an IEEE member with nearly 10 years of Linux operation and maintenance experience it is not difficult to boot the image I need through the network when you don't want to add iso, but it will be more troublesome than using iso directly, so if There is not much principle or technical problem. Adding these iso can make it easier for more people to use.
发表于 2018-7-12 17:40:52 | 只看该作者
我tk用英文,客服回中文
发表于 2018-7-12 18:27:34 | 只看该作者
GMT+8, 2026-4-13 09:22 , Processed in 0.072178 second(s), 11 queries , Gzip On, MemCache On.
