查看: 5660|回复: 13
[疑问] apache装好了,HTML不解析?是html啊!
发表于 2011-1-26 14:53:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
FreeBSD,用ports安装的,难道是少安装了什么模块?
打开页面直接来个 <html><body><h1>It works!</h1></body></html>
自己编译apache安装没问题,ports安装nginx没问题.....
可选模块一览,帮忙看看是不是少了哪个?
              [ ] THREADS               Enable threads support in APR         x x
           x x[ ] MYSQL                 Enable MySQL support for apr-dbd      x x
           x x[ ] PGSQL                 Enable PostgreSQL support for apr-dbd x x
           x x[ ] SQLITE                Enable SQLite support for apr-dbd     x x
           x x[ ] IPV6                  Enable IPv6 support                   x x
           x x[ ] BDB                   Enable BerkeleyDB dbm                 x x
           x x[ ] AUTH_BASIC            Enable mod_auth_basic                 x x
           x x[ ] AUTH_DIGEST           Enable mod_auth_digest                x x
           x x[ ] AUTHN_FILE            Enable mod_authn_file                 x x
           x x[ ] AUTHN_DBD             Enable mod_authn_dbd                  x x
           x x[ ] AUTHN_DBM             Enable mod_authn_dbm                  x x
           x x[ ] AUTHN_ANON            Enable mod_authn_anon                 x x
           x x[X] AUTHN_DEFAULT         Enable mod_authn_default              x x
           x x[ ] AUTHN_ALIAS           Enable mod_authn_alias                x x
           x x[X] AUTHZ_HOST            Enable mod_authz_host
             x[ ] AUTHZ_GROUPFILE       Enable mod_authz_groupfile            x x
           x x[ ] AUTHZ_USER            Enable mod_authz_user                 x x
           x x[ ] AUTHZ_DBM             Enable mod_authz_dbm                  x x
           x x[ ] AUTHZ_OWNER           Enable mod_authz_owner                x x
           x x[ ] AUTHZ_DEFAULT         Enable mod_authz_default              x x
           x x[ ] CACHE                 Enable mod_cache                      x x
           x x[ ] DISK_CACHE            Enable mod_disk_cache                 x x
           x x[ ] FILE_CACHE            Enable mod_file_cache                 x x
           x x[ ] MEM_CACHE             Enable mod_mem_cache                  x x
           x x[ ] DAV                   Enable mod_dav                        x x
           x x[ ] DAV_FS                Enable mod_dav_fs                     x x
           x x[ ] BUCKETEER             Enable mod_bucketeer                  x x
           x x[ ] CASE_FILTER           Enable mod_case_filter                x x
           x x[ ] CASE_FILTER_IN        Enable mod_case_filter_in             x x
           x x[ ] EXT_FILTER            Enable mod_ext_filter
              [ ] LOG_FORENSIC          Enable mod_log_forensic               x x
           x x[ ] OPTIONAL_HOOK_EXPORT  Enable mod_optional_hook_export       x x
           x x[ ] OPTIONAL_HOOK_IMPORT  Enable mod_optional_hook_import       x x
           x x[ ] OPTIONAL_FN_IMPORT    Enable mod_optional_fn_import         x x
           x x[ ] OPTIONAL_FN_EXPORT    Enable mod_optional_fn_export         x x
           x x[ ] LDAP                  Enable mod_ldap                       x x
           x x[ ] AUTHNZ_LDAP           Enable mod_authnz_ldap                x x
           x x[ ] ACTIONS               Enable mod_actions                    x x
           x x[ ] ALIAS                 Enable mod_alias                      x x
           x x[ ] ASIS                  Enable mod_asis                       x x
           x x[ ] AUTOINDEX             Enable mod_autoindex                  x x
           x x[ ] CERN_META             Enable mod_cern_meta                  x x
           x x[ ] CGI                   Enable mod_cgi                        x x
           x x[ ] CHARSET_LITE          Enable mod_charset_lite               x x
           x x[ ] DBD                   Enable mod_dbd                        x x
[X] DEFLATE               Enable mod_deflate                    x x
           x x[X] DIR                   Enable mod_dir                        x x
           x x[ ] DUMPIO                Enable mod_dumpio                     x x
           x x[ ] ENV                   Enable mod_env                        x x
           x x[X] EXPIRES               Enable mod_expires                    x x
           x x[X] HEADERS               Enable mod_headers                    x x
           x x[ ] IMAGEMAP              Enable mod_imagemap                   x x
           x x[ ] INCLUDE               Enable mod_include                    x x
           x x[X] INFO                  Enable mod_info                       x x
           x x[X] LOG_CONFIG            Enable mod_log_config                 x x
           x x[ ] LOGIO                 Enable mod_logio                      x x
           x x[ ] MIME                  Enable mod_mime                       x x
           x x[ ] MIME_MAGIC            Enable mod_mime_magic                 x x
           x x[ ] NEGOTIATION           Enable mod_negotiation                x x
           x x[X] REWRITE               Enable mod_rewrite
[ ] SETENVIF              Enable mod_setenvif                   x x
           x x[ ] SPELING               Enable mod_speling                    x x
           x x[ ] STATUS                Enable mod_status                     x x
           x x[ ] UNIQUE_ID             Enable mod_unique_id                  x x
           x x[ ] USERDIR               Enable mod_userdir                    x x
           x x[ ] USERTRACK             Enable mod_usertrack                  x x
           x x[ ] VHOST_ALIAS           Enable mod_vhost_alias                x x
           x x[ ] FILTER                Enable mod_filter                     x x
           x x[ ] VERSION               Enable mod_version                    x x
           x x[ ] PROXY                 Enable mod_proxy                      x x
           x x[ ] PROXY_CONNECT         Enable mod_proxy_connect              x x
           x x[ ] PATCH_PROXY_CONNECT   Patch proxy_connect SSL support       x x
           x x[ ] PROXY_FTP             Enable mod_proxy_ftp                  x x
           x x[ ] PROXY_HTTP            Enable mod_proxy_http                 x x
           x x[ ] PROXY_AJP             Enable mod_proxy_ajp
              [ ] PROXY_BALANCER        Enable mod_proxy_balancer             x x
           x x[ ] PROXY_SCGI            Enable mod_proxy_scgi                 x x
           x x[ ] SSL                   Enable mod_ssl                        x x
           x x[ ] SUEXEC                Enable mod_suexec                     x x
           x x[ ] SUEXEC_RSRCLIMIT      SuEXEC rlimits based on login class   x x
           x x[X] REQTIMEOUT            Enable mod_reqtimeout                 x x
           x x[ ] CGID                  Enable mod_cgid
额,难道html还需要额外设置?不是都是浏览器解决的么?
发表于 2011-1-26 14:55:12 | 只看该作者
这个悲剧了
发表于 2011-1-26 14:56:13 | 只看该作者
你html文件写的有问题吧
 楼主| 发表于 2011-1-26 14:59:17 | 只看该作者
回复 3# 的帖子
额,那个是apache的默认测试页面,别的都能打开,就我的解析不了,另外,我换了别的html试过,也是显示代码,不现实页面
发表于 2011-1-26 14:59:58 | 只看该作者
技术不到家
发表于 2011-1-26 15:05:37 | 只看该作者
DefaultType text/html 或者 addType text/html .html
 楼主| 发表于 2011-1-26 15:10:00 | 只看该作者
原帖由 cnweb 于 2011-1-26 14:59 发表
技术不到家
所以来请技术到家的指导啊
发表于 2011-1-26 15:10:59 | 只看该作者
有点意思
发表于 2011-1-26 15:12:36 | 只看该作者
原帖由 Kokgog 于 2011-1-26 15:05 发表
 楼主| 发表于 2011-1-26 17:43:24 | 只看该作者
回复 9# 的帖子
事实证明不是这个原因
GMT+8, 2026-1-1 08:23 , Processed in 0.066364 second(s), 10 queries , Gzip On, MemCache On.
