CeraNetworks网络延迟测速工具IP归属甄别
查看: 4194|回复: 5
如果一台主机是offshore(避开版权)的话,那整个机房都是?
发表于 2011-1-23 22:44:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
小弟是买了ah的一台offshore主机,查了下ip是卢森堡的的root esolution idc,贵了一倍了
但是跑到idc官网查询aup的时候,发现是这样的
2.11 Breach of Copyright
The Customer is prohibited either from offering or
distributing any information which is protected by
copyright without lawful authority. The operating of so
called P2P exchanges, download services or
streaming services over which copyright protected
information could be distributed without lawful
authority is not permitted. It is also prohibited to make
available links which connect to P2P exchanges,
download services, streaming services or information
provided by them. In case of infringement root S.A.
reserves the right to remove the server from the
network without prior warning and to terminate the
agreement.
不过我也不会做stream或者download,只是发warez链接,给idc询问的邮件也还没回,
我不晓得idc放那个aup是不是个形式。
发表于 2011-1-24 15:14:53 | 只看该作者
立陶宛有个机房说可以做ware link和adult
 楼主| 发表于 2011-1-24 15:47:08 | 只看该作者
给个link去瞧瞧
不过立陶宛不是东欧国家么,带宽质量能比上北欧?
发表于 2011-1-25 00:40:47 | 只看该作者
立陶宛的速度是比较一般
发表于 2011-1-25 19:05:30 | 只看该作者
做warez 还是到香港把。
发表于 2011-2-10 23:02:01 | 只看该作者
原帖由 Host.HowPick 于 2011-1-25 19:05 发表
做warez 还是到香港把。
可惜带宽太小了。
GMT+8, 2026-5-1 16:16 , Processed in 0.063245 second(s), 9 queries , Gzip On, MemCache On.
