查看: 5229|回复: 2
请问这个信件是什么意思呢?
发表于 2009-10-7 11:37:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Support Staff Response
Dear Sir/Maddam
Thank You for contacting online Support,
Unfortunately Go Daddy cannot completely remove a customer account from our system for legal reasons. However, you can use the instructions below to cancel all products or services for this account, remove all payment methods from this account, and turn off all opt-in email notifications. Company policy restricts Go Daddy Customer Support representatives from making changes to customer accounts or services on behalf of the customer. You will need to make this change from within your account.
To cancel all products and services, follow the directions below:
First, log into your customer account:
• Go to the Go Daddy Account Login Page
• Log in using your account username (which may be the same as your customer number) and password
If you have trouble logging in, our password reset form may help you. You can find this form through the following link:
Account Retrieval Page
Once you have logged in to your account, follow the steps below to cancel:
• Select 'Payments and Renewing Items' from the 'Renewals & Upgrades' menu.
• Check the box next to the item(s) you would like to cancel and click on the 'Cancel Item' button.
• Select 'Cancel Now' or 'Cancel at Expiration Date' in the menu that appears to the right.
• Click on 'Save Changes'.
*Canceling now will immediately remove the service from your account. If you choose to "Cancel at Expiration Date" the service will remain active until the date specified and will not be renewed.
Please use the below instructions to remove a payment method from our system. Note that there must be no products or services in our system which are currently linked to that payment method before you can remove it.
• Select 'Credit Card & Payment Info' from the 'My Account' menu
• Select the radio button next to the desired payment method in the list.
• Click the 'Deactivate Payment Method' button.
• If there are any products or services currently associated with this item you will then be forced to move them to another payment method before you can continue.
• After moving any products or services to another payment method, click the 'Save Changes' button.
You can choose not to receive email notices by updating your customer account settings. Follow the directions below:
• Select 'Account Settings' from the 'My Account' menu.
• Click on the "Email Preference Information" link.
• Go through the choices and select your preference for each.
• When you are done, click on the green "Save Changes" button.
You can also use the "UNSUBSCRIBE" link found at the bottom of all the notices that we send out.
Please let us know if there is anything else we can assit you with.
Regards,
Lou V
Online Support
 楼主| 发表于 2009-10-7 11:37:45 | 只看该作者
先谢谢大大的帮忙!
发表于 2009-10-7 22:50:55 | 只看该作者
回复 1# 的帖子
他们不能随便移除空间帐号,需要帐号持有者自己登陆去取消域名绑定或者相应的空间。
GMT+8, 2026-4-19 21:21 , Processed in 0.057517 second(s), 11 queries , Gzip On, MemCache On.
