查看: 7437|回复: 32
[Windows VPS] hetzner 给我来了邮件
发表于 2018-5-11 21:38:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
hetzner莫名其妙给我来了封邮件,一直不解其意,dalao们帮我看看是什么情况
---------------------------------------------邮件内容------------------------------------
Dear Sir or Madam
We have noticed that you have been using other IPs and MACs in addition to
the main IP mentioned in
the above subject line.
As this is not permitted, we regret to inform you that your server has been
deactivated.
Guidelines regarding further course of action may be found in our wiki:
http://wiki.hetzner.de/index.php/Leitfaden_bei_Serversperrung/en.
Yours faithfully
Your Hetzner Support Team
00:50:56:00:1f:70 - ge-0/0/2.0
0a:ca:a5:b5:9b:db - ge-0/0/2.0
1e:62:4f:8c:cf:0a - ge-0/0/2.0
36:93:ba:32:a7:bd - ge-0/0/2.0
3a:d8:99:48:e4:e2 - ge-0/0/2.0
3e:03:79:a0:9d:3c - ge-0/0/2.0
46:95:22:1c:40:89 - ge-0/0/2.0
54:04:a6:b2:14:08 - ge-0/0/2.0
62:2c:fd:5f:38:cc - ge-0/0/2.0
7e:cc:0c:95:05:3b - ge-0/0/2.0
86:9a:b0:b0:e9:f0 - ge-0/0/2.0
8e:bd:6c:01:3d:a5 - ge-0/0/2.0
a2:a1:82:0e:19:ca - ge-0/0/2.0
ba:1a:ea:19:11:83 - ge-0/0/2.0
c6:10:95:23:c1:05 - ge-0/0/2.0
d2:31:42:62:f2:7b - ge-0/0/2.0
d2:4a:58:9d:4f:ae - ge-0/0/2.0
f2:72:56:c1:14:19 - ge-0/0/2.0
May 11 14:09:20 213.133.117.202 fpc2 PFE_FW_SYSLOG_ETH_IP: FW: xe-2/1/4.100 D
0064:0800 00:50:56:00:1f:70 -> 84:c1:c1:76:a9:77  tcp 192.168.132.13
180.163.251.43  2404    80 (1 packets)
May 11 14:09:38 213.133.117.202 fpc2 PFE_FW_SYSLOG_ETH_IP: FW: xe-2/1/4.100 D
0064:0800 00:50:56:00:1f:70 -> 84:c1:c1:76:a9:77 icmp 192.168.132.21
23.248.239.205     8     0 (30526 packets)
May 11 14:09:53 213.133.117.202 fpc2 PFE_FW_SYSLOG_ETH_IP: FW: xe-2/1/4.100 D
0064:0800 86:9a:b0:b0:e9:f0 -> ff:ff:ff:ff:ff:ff  udp 192.168.132.24
192.168.132.255   137   137 (7 packets)
May 11 14:10:26 213.133.117.202 fpc2 PFE_FW_SYSLOG_ETH_IP: FW: xe-2/1/4.100 D
0064:0800 3e:03:79:a0:9d:3c -> ff:ff:ff:ff:ff:ff  udp 192.168.132.15
192.168.132.255   138   138 (1 packets)
May 11 14:11:21 213.133.117.202 fpc2 PFE_FW_SYSLOG_ETH_IP: FW: xe-2/1/4.100 D
23.248.239.205     0     0 (30526 packets)
May 11 14:11:22 213.133.117.202 fpc2 PFE_FW_SYSLOG_ETH_IP: FW: xe-2/1/4.100 D
0064:0800 c6:10:95:23:c1:05 -> ff:ff:ff:ff:ff:ff  udp 192.168.132.23
May 11 14:11:23 213.133.117.202 fpc2 PFE_FW_SYSLOG_ETH_IP: FW: xe-2/1/4.100 D
0064:0800 a2:a1:82:0e:19:ca -> ff:ff:ff:ff:ff:ff  udp 192.168.132.10
192.168.132.255   138   138 (3 packets)
May 11 14:13:01 213.133.117.202 fpc2 PFE_FW_SYSLOG_ETH_IP: FW: xe-2/1/4.100 D
23.248.239.205     8     0 (30542 packets)
May 11 14:13:02 213.133.117.202 fpc2 PFE_FW_SYSLOG_ETH_IP: FW: xe-2/1/4.100 D
23.248.239.205     0     0 (30542 packets)
May 11 14:13:31 213.133.117.202 fpc2 PFE_FW_SYSLOG_ETH_IP: FW: xe-2/1/4.100 D
0064:0800 0a:ca:a5:b5:9b:db -> ff:ff:ff:ff:ff:ff  udp 192.168.132.27
May 11 14:14:34 213.133.117.202 fpc2 PFE_FW_SYSLOG_ETH_IP: FW: xe-2/1/4.100 D
192.168.132.255   138   138 (12 packets)
May 11 14:14:37 213.133.117.202 fpc2 PFE_FW_SYSLOG_ETH_IP: FW: xe-2/1/4.100 D
0064:0800 7e:cc:0c:95:05:3b -> ff:ff:ff:ff:ff:ff  udp 192.168.132.14
192.168.132.255   137   137 (2 packets)
May 11 14:14:45 213.133.117.202 fpc2 PFE_FW_SYSLOG_ETH_IP: FW: xe-2/1/4.100 D
发表于 2018-5-11 22:09:56 来自手机 | 只看该作者
不让开小鸡  这不科学
发表于 2018-5-11 21:40:20 | 只看该作者
你是不是开nat小鸡了...用的ip6被封机器了..
 楼主| 发表于 2018-5-11 21:41:00 | 只看该作者
是开了Nat小鸡
发表于 2018-5-11 21:43:38 | 只看该作者
发TK 看看能不能恢复机器,说点软话..或许能放你一马
 楼主| 发表于 2018-5-11 21:44:15 | 只看该作者
是什么情况,大佬您能不能说一下
发表于 2018-5-11 21:46:57 | 只看该作者
已经很明白了...
您除了使用IP和Mac之外,还使用了其他的IP和Mac
 楼主| 发表于 2018-5-11 21:47:29 | 只看该作者
myseil 发表于 2018-5-11 21:46
已经很明白了...
内外ip都不行吗
发表于 2018-5-11 21:50:29 | 只看该作者
应该是使用了其他的mac造成的.
发TK  看看能恢复不
发表于 2018-5-11 21:51:14 | 只看该作者
看起来不让开小鸡?
 楼主| 发表于 2018-5-11 21:52:51 来自手机 | 只看该作者
myseil 发表于 2018-5-11 21:50
应该是使用了其他的mac造成的.
嗯,谢谢啦
稳了20多天。。
GMT+8, 2025-12-26 20:12 , Processed in 0.083948 second(s), 9 queries , Gzip On, MemCache On.
