查看: 3543|回复: 4
今天从装了后端不知道为什么变成这样。望高手帮帮我看看
发表于 2018-4-24 12:57:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
2018-04-24 00:43:15 INFO     util.py:85 loading libcrypto from libcrypto.so.10
2018-04-24 00:43:15 INFO     asyncdns.py:324 dns server: [('4.2.2.1', 53), ('4.2.2.2', 53)]
2018-04-24 00:43:15 INFO     db_transfer.py:201 current process RLIMIT_NOFILE resource: soft 512000 hard 512000
2018-04-24 00:43:15 ERROR    db_transfer.py:215 Traceback (most recent call last):
  File "/usr/local/legendsock/db_transfer.py", line 208, in thread_db
    rows = db_instance.pull_db_all_user()
  File "/usr/local/legendsock/db_transfer.py", line 311, in pull_db_all_user
    import cymysql
ImportError: No module named cymysql
发表于 2018-4-24 13:03:14 | 只看该作者
  import cymysql
很明显?
发表于 2018-4-24 13:04:10 | 只看该作者
pip install  cymysql
 楼主| 发表于 2018-4-24 13:27:23 | 只看该作者
[root@Centos176 ~]# pip install  cymysql
  File "/usr/bin/pip", line 9, in <module>
    load_entry_point('pip==10.0.1', 'console_scripts', 'pip')()
  File "/usr/lib/python2.6/site-packages/pkg_resources.py", line 299, in load_entry_point
    return get_distribution(dist).load_entry_point(group, name)
  File "/usr/lib/python2.6/site-packages/pkg_resources.py", line 2229, in load_entry_point
    return ep.load()
  File "/usr/lib/python2.6/site-packages/pkg_resources.py", line 1948, in load
    entry = __import__(self.module_name, globals(),globals(), ['__name__'])
  File "/usr/lib/python2.6/site-packages/pip-10.0.1-py2.6.egg/pip/_internal/__init__.py", line 42, in <module>
    from pip._internal import cmdoptions
  File "/usr/lib/python2.6/site-packages/pip-10.0.1-py2.6.egg/pip/_internal/cmdoptions.py", line 16, in <module>
    from pip._internal.index import (
  File "/usr/lib/python2.6/site-packages/pip-10.0.1-py2.6.egg/pip/_internal/index.py", line 526
    {str(c.version) for c in all_candidates},
SyntaxError: invalid syntax
 楼主| 发表于 2018-4-24 13:38:48 | 只看该作者
    return ep.load()
请问是什么问题了
GMT+8, 2026-1-3 10:14 , Processed in 0.135139 second(s), 10 queries , Gzip On, MemCache On.
