查看: 5657|回复: 25
[疑问] 250Mbps的KS-2A上架了
发表于 2018-4-9 21:07:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
毫无疑问, 被忽悠了.
  1. ----------------------------------------------------------------------
  2. CPU model            : Intel(R) Atom(TM) CPU N2800   [url=home.php?mod=space&uid=175]@[/url] 1.86GHz
  3. Number of cores      : 4
  4. CPU frequency        : 1330.000 MHz
  5. Total size of Disk   : 919.5 GB (1.1 GB Used)
  6. Total amount of Mem  : 3938 MB (72 MB Used)
  7. Total amount of Swap : 510 MB (0 MB Used)
  8. System uptime        : 0 days, 0 hour 10 min
  9. Load average         : 0.16, 0.55, 0.36
  10. OS                   : Debian GNU/Linux 9
  11. Arch                 : x86_64 (64 Bit)
  12. Kernel               : 4.9.0-6-amd64
  13. ----------------------------------------------------------------------
  14. I/O speed(1st run)   : 133 MB/s
  15. I/O speed(2nd run)   : 133 MB/s
  16. I/O speed(3rd run)   : 130 MB/s
  17. Average I/O speed    : 132.0 MB/s
  18. ----------------------------------------------------------------------
  19. Node Name                       IPv4 address            Download Speed
  20. CacheFly                        205.234.175.175         10.2MB/s
  21. Linode, Tokyo, JP               2400:8900::4b           4.27MB/s
  22. Linode, Singapore, SG           2400:8901::4b           2.18MB/s
  23. Linode, London, UK              2a01:7e00::4b           11.0MB/s
  24. Linode, Frankfurt, DE           2a01:7e01::4b           10.4MB/s
  25. Linode, Fremont, CA             2600:3c01::4b           4.51MB/s
  26. Softlayer, Dallas, TX           2607:f0d0:1101:4::2     1.95MB/s
  27. Softlayer, Seattle, WA          2607:f0d0:2001:3::2     8.18MB/s
  28. Softlayer, Frankfurt, DE        2a03:8180:1201:45::4    11.2MB/s
  29. Softlayer, Singapore, SG        2401:c900:1101:8::2     2.56MB/s
  30. Softlayer, HongKong, CN         119.81.130.170          3.79MB/s
  31. ----------------------------------------------------------------------
  32. Node Name                       IPv6 address            Download Speed
  33. Linode, Atlanta, GA             2600:3c02::4b           10.0MB/s
  34. Linode, Dallas, TX              2600:3c00::4b           6.32MB/s
  35. Linode, Newark, NJ              2600:3c03::4b           4.51MB/s
  36. Linode, Singapore, SG           2400:8901::4b           4.44MB/s
  37. Linode, Tokyo, JP               2400:8900::4b           2.61MB/s
  38. Softlayer, San Jose, CA         2607:f0d0:2601:2a::4    4.64MB/s
  39. Softlayer, Washington, WA       2607:f0d0:3001:78::2    6.32MB/s
  40. Softlayer, Paris, FR            2a03:8180:1301:8::4     6.88MB/s
  41. Softlayer, Singapore, SG        2401:c900:1101:8::2     3.32MB/s
  42. Softlayer, Tokyo, JP            2401:c900:1001:16::4    1.89MB/s
  43. ----------------------------------------------------------------------
说好的 250Mbps 呢? 信任呢? 没上车的娃可以散了~
发表于 2018-4-9 21:08:37 | 只看该作者
发tk和他们怼, 要求改为250Mbps
发表于 2018-4-9 21:10:01 来自手机 | 只看该作者
我靠 我的也上架了 还没有安装系统 如果不是250mb 我要退了 日
发表于 2018-4-9 21:11:02 | 只看该作者
来啊,逮到一只猴
发表于 2018-4-9 21:13:02 | 只看该作者
你这是下载,可能上传是呢。测试一下上传
发表于 2018-4-9 21:13:30 | 只看该作者
截图官网保存证据,试试怼客服。
ps:ks1有货了6欧的
发表于 2018-4-9 21:14:15 | 只看该作者
  1. wget -qO- https://raw.githubusercontent.com/oooldking/script/master/superbench.sh | bash
这个可以测试上传
发表于 2018-4-9 21:14:38 | 只看该作者
不是,官网都改了
发表于 2018-4-9 21:19:25 | 只看该作者
贼梦贼康 发表于 2018-4-9 21:14
不是,官网都改了
我这看到官网还是250mb呢
 楼主| 发表于 2018-4-9 21:22:32 | 只看该作者
openos 发表于 2018-4-9 21:14
这个可以测试上传
  2. Node Name         Upload Speed      Download Speed      Latency
  3. Normal Node       92.33 Mbit/s      94.31 Mbit/s        22.021 ms
  4. Xiangyang CT      0.70 Mbit/s       3.72 Mbit/s         699.625 ms
  5. Kunming   CT      0.61 Mbit/s       1.67 Mbit/s         000.000 ms
  6. Chengdu   CT      3.87 Mbit/s       31.03 Mbit/s        994.029 ms
  7. Shenyang  CU      16.63 Mbit/s      27.18 Mbit/s        444.187 ms
  8. Xi'an     CU      3.28 Mbit/s       13.99 Mbit/s        413.37 ms
  9. Shanghai  CU      4.00 Mbit/s       8.85 Mbit/s         368.221 ms
  10. Chongqing CU      2.67 Mbit/s       2.70 Mbit/s         000.000 ms
怼ticket 去
GMT+8, 2026-4-16 10:03 , Processed in 0.061359 second(s), 8 queries , Gzip On, MemCache On.
