查看: 2584|回复: 4
求助——已解决
发表于 2009-10-2 23:45:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
好不容易把前面碰到的问题都解决了,可在线解压缩的时候又失败了,提示如下:
什么意思啊?怎么解决呢?
谢谢各位!
Please NOTE: The graph on the left of each file, seen after you have clicked on the disk usage , shows the usage of that file relative to the total. When the tag on the graph says "file a.tar.gz uses 10MB of 30MB", it means that the total size occupied by the all the files in the directory is 30MB, and a.tar.gz uses 10MB. This is in no way related to your total disk quota. The graph merely shows the size of one file in relation to the total used by all the files in that particular directory.
Normally, the actual disk space occupied by the directories is not shown. Click on disk space so that instead of showing the '0' or '4096' against the directory size, the listing will show the actual space occupied by the directories. Please note that this is a resource intensive process, and will take a bit of time. Also, this is a one time operation. If you want to see the disk usages again, you have to click on disk space again.
You can sort by real size by clicking on the size and then clicking on disk space
[ 本帖最后由 37love 于 2009-10-3 00:13 编辑 ]
发表于 2009-10-3 00:06:40 | 只看该作者
 楼主| 发表于 2009-10-3 00:09:42 | 只看该作者
我解压不了,不知道该怎么办……
 楼主| 发表于 2009-10-3 00:13:36 | 只看该作者
搞定了,原来是文件名里面不能有空格~~
谢谢2楼的兄弟!
发表于 2009-10-3 00:39:37 | 只看该作者
回复 4# 的帖子
最还名字用字母+数字。
GMT+8, 2026-4-30 21:35 , Processed in 0.061135 second(s), 10 queries , Gzip On, MemCache On.
