查看: 12154|回复: 1
Proxmox开openvz小鸡出错
发表于 2018-3-29 12:59:56 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
出错信息如下,求高人告知出错原因,proxmox4.4/5都出这个问题。
Formatting '/var/lib/vz/images/101/vm-101-disk-2.raw', fmt=raw size=53687091200
mke2fs 1.42.12 (29-Aug-2014)
Discarding device blocks:     4096/13107200                 done
Creating filesystem with 13107200 4k blocks and 3276800 inodes
Filesystem UUID: e3c81e26-5e54-4129-b0c7-c6f264add0e9
Superblock backups stored on blocks:
        32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
        4096000, 7962624, 11239424
Allocating group tables:   0/400       done
Writing inode tables:   0/400       done
Creating journal (32768 blocks): done
Multiple mount protection is enabled with update interval 5 seconds.
Writing superblocks and filesystem accounting information:   0/400
Warning, had trouble writing out superblocks.TASK ERROR: command 'mkfs.ext4 -O mmp -E 'root_owner=0:0' /var/lib/vz/images/101/vm-101-disk-2.raw' failed: exit code 144
 楼主| 发表于 2018-3-29 13:08:52 来自手机 | 只看该作者
是用ks2e的,怎么开也不行
GMT+8, 2026-4-21 11:58 , Processed in 0.061810 second(s), 9 queries , Gzip On, MemCache On.
