查看: 2981|回复: 8
这下挂了·菜鸟就是菜鸟· 来个高手指点下啊·
发表于 2011-1-7 22:46:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
貌似我没动什么,顶多是绑定子目录啊,配置我也没动过
  1. [root@server /]# service nginx restart
  2. [emerg]: unknown "bref_3d" variable
  3. configuration file /usr/local/nginx/conf/nginx.conf test failed
  4. [root@server /]#
失败@我就去重启VPS,这倒好,网站直接访问不了了,那个SSH、SFTP都能连接上····
指点一下啊,实在没人理,我就玩完了,没备份数据库@###
nginx.conf配置文件
  1. user  www www;
  2. worker_processes 1;
  3. error_log  /home/www/logs/nginx_error.log  crit;
  4. pid        /usr/local/nginx/nginx.pid;
  5. #Specifies the value for maximum file descriptors that can be opened by this process.
  6. worker_rlimit_nofile 1024;
  7. events
  8.         {
  9.                 use epoll;
  10.                 worker_connections 1024;
  11.         }
  12. http
  13.         {
  14.                 include       mime.types;
  15.                 default_type  application/octet-stream;
  16.                 #charse  gb2312;
  17.                 server_names_hash_bucket_size 128;
  18.                 client_header_buffer_size 128k;
  19.                 large_client_header_buffers 4 256k;
  20.                 client_max_body_size 16m;
  21.                 sendfile on;
  22.                 tcp_nopush     on;
  23.                 keepalive_timeout 60;
  24.                 tcp_nodelay on;
  25.                 fastcgi_connect_timeout 300;
  26.                 fastcgi_send_timeout 300;
  27.                 fastcgi_read_timeout 300;
  28.                 fastcgi_buffer_size 64k;
  29.                 fastcgi_buffers 4 64k;
  30.                 fastcgi_busy_buffers_size 128k;
  31.                 fastcgi_temp_file_write_size 128k;
  32.                 gzip on;
  33.                 gzip_min_length  1k;
  34.                 gzip_buffers     4 16k;
  35.                 gzip_http_version 1.1;
  36.                 gzip_comp_level 9;
  37.                 gzip_types       text/plain application/x-javascript text/css application/xml;
  38.                 gzip_vary on;
  39.                 output_buffers   4 32k;
  40.                 postpone_output  1460;
  41.                 #limit_zone  crawler  $binary_remote_addr  10m;
  42.
  43. server
  44.         {
  45.                 listen       80;
  46.                 server_name uubus.cc;
  47.                 index index.html index.htm index.php;
  48.                 include location.conf;
  49.                 include uubus.conf;
  50.                 root  /home/www;
  51.         }
  52.                 include servers/*;
  53. }
  1. 2010/12/09 15:14:25 [warn] 3161#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  2. 2010/12/09 15:14:54 [warn] 3208#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  3. 2010/12/11 09:04:56 [warn] 21863#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  4. 2010/12/19 18:03:39 [warn] 14168#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  5. 2010/12/19 18:04:03 [warn] 15654#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  6. 2010/12/19 18:04:03 [warn] 15659#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  7. 2010/12/19 18:36:36 [warn] 16226#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  8. 2010/12/19 18:36:36 [warn] 16231#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  9. 2010/12/19 18:45:28 [warn] 15810#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  10. 2010/12/19 18:46:06 [warn] 28157#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  11. 2010/12/19 18:46:20 [warn] 5189#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  12. 2010/12/19 18:46:20 [warn] 5194#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  13. 2010/12/20 12:56:38 [warn] 3343#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  14. 2010/12/20 12:56:38 [warn] 3595#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  15. 2010/12/21 13:41:13 [warn] 7760#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  16. 2010/12/21 13:42:08 [warn] 9643#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  17. 2010/12/21 13:44:57 [warn] 13914#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  18. 2010/12/21 13:45:13 [warn] 28671#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  19. 2010/12/21 13:45:58 [warn] 30055#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  20. 2010/12/21 13:45:58 [warn] 30060#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  21. 2010/12/23 20:47:49 [warn] 19749#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  22. 2010/12/23 20:47:50 [warn] 19839#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  23. 2010/12/24 21:16:17 [warn] 23670#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  24. 2010/12/24 21:18:31 [warn] 27656#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  25. 2010/12/24 21:18:31 [warn] 27663#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  26. 2010/12/25 18:08:10 [warn] 3091#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  27. 2010/12/26 13:29:44 [warn] 25743#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  28. 2010/12/26 14:12:39 [warn] 13949#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  29. 2010/12/27 21:54:00 [warn] 22270#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  30. 2010/12/28 13:17:24 [warn] 3530#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  31. 2010/12/28 13:18:23 [warn] 7911#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  32. 2010/12/28 21:18:21 [warn] 12071#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  33. 2010/12/28 21:18:21 [emerg] 12071#0: open() "/home/www/logs/nginx_error.log" failed (2: No such file or directory)
  34. 2010/12/28 21:18:48 [warn] 14255#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  35. 2010/12/28 21:18:48 [emerg] 14255#0: open() "/home/www/logs/nginx_error.log" failed (2: No such file or directory)
  36. 2010/12/28 21:22:25 [warn] 14306#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  37. 2010/12/28 21:22:26 [warn] 14332#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  38. 2010/12/30 09:58:24 [warn] 30653#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  39. 2010/12/30 10:04:35 [warn] 23859#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  40. 2010/12/31 14:15:47 [warn] 27677#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  41. 2011/01/05 16:00:34 [warn] 9665#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  42. 2011/01/06 15:57:54 [warn] 11556#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  43. 2011/01/06 18:09:42 [warn] 11588#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  44. 2011/01/06 19:10:45 [warn] 3827#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  45. 2011/01/07 12:04:03 [warn] 32139#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  46. 2011/01/07 12:04:41 [warn] 32532#0: conflicting server name "uubus.cc" on 0.0.0.0:80, ignored
  47. 2011/01/07 17:09:19 [emerg] 5613#0: unknown "bref_3d" variable
  48. 2011/01/07 17:09:39 [emerg] 5898#0: unknown "bref_3d" variable
  49. 2011/01/07 17:10:27 [emerg] 28575#0: unknown "bref_3d" variable
  50. 2011/01/07 17:23:27 [emerg] 1669#0: unknown "bref_3d" variable
  51. 2011/01/07 17:26:00 [emerg] 30049#0: unknown "bref_3d" variable
  52. 2011/01/07 17:33:43 [emerg] 5587#0: unknown "bref_3d" variable
  53. 2011/01/07 17:39:16 [emerg] 5363#0: unknown "bref_3d" variable
  54. 2011/01/07 17:39:42 [emerg] 5718#0: unknown "bref_3d" variable
[ 本帖最后由 菜鸟也疯狂 于 2011-1-7 22:50 编辑 ]
发表于 2011-1-7 22:48:18 | 只看该作者
vi /usr/local/nginx/conf/nginx.conf 然后把配置文件贴上来。
 楼主| 发表于 2011-1-7 22:49:51 | 只看该作者
嗯,贴上去了@
 楼主| 发表于 2011-1-7 22:53:01 | 只看该作者
这个 大哥可以修好不?
发表于 2011-1-7 22:53:08 | 只看该作者
这俩文件里是什么?
                include uubus.conf;
发表于 2011-1-7 22:54:33 | 只看该作者
这个 uubus.conf 也贴出来吧...
发表于 2011-1-7 22:56:13 | 只看该作者
 楼主| 发表于 2011-1-7 22:57:08 | 只看该作者
这2个·不知道·下面那个好像是伪静态规则,好像以前添加错了吧··
 楼主| 发表于 2011-1-7 22:58:17 | 只看该作者
没印象·好像刚开始弄的时候, 绑了吧··
GMT+8, 2026-4-21 20:53 , Processed in 0.065343 second(s), 10 queries , Gzip On, MemCache On.
