查看: 3073|回复: 8
这个测试的分还可以吧
发表于 2011-1-5 07:44:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Benchmark Run: Wed Jan 05 2011 01:00:53 - 01:29:08
4 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       13867117.5 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     2873.1 MWIPS (9.9 s, 7 samples)
Execl Throughput                               3723.3 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        411211.8 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          140219.2 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        893187.5 KBps  (30.0 s, 2 samples)
Pipe Throughput                              952230.7 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 140675.3 lps   (10.0 s, 7 samples)
Process Creation                              13422.6 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   6952.9 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   2198.5 lpm   (60.0 s, 2 samples)
System Call Overhead                         795108.1 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   13867117.5   1188.3
Double-Precision Whetstone                       55.0       2873.1    522.4
Execl Throughput                                 43.0       3723.3    865.9
File Copy 1024 bufsize 2000 maxblocks          3960.0     411211.8   1038.4
File Copy 256 bufsize 500 maxblocks            1655.0     140219.2    847.2
File Copy 4096 bufsize 8000 maxblocks          5800.0     893187.5   1540.0
Pipe Throughput                               12440.0     952230.7    765.5
Pipe-based Context Switching                   4000.0     140675.3    351.7
Process Creation                                126.0      13422.6   1065.3
Shell Scripts (1 concurrent)                     42.4       6952.9   1639.8
Shell Scripts (8 concurrent)                      6.0       2198.5   3664.1
System Call Overhead                          15000.0     795108.1    530.1
System Benchmarks Index Score                                         966.6
Benchmark Run: Wed Jan 05 2011 01:29:08 - 01:57:22
4 CPUs in system; running 4 parallel copies of tests
Dhrystone 2 using register variables       55429923.1 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                    11478.2 MWIPS (9.9 s, 7 samples)
Execl Throughput                              13854.9 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        136810.4 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           41399.6 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        329302.8 KBps  (30.0 s, 2 samples)
Pipe Throughput                             3796219.4 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                1231507.4 lps   (10.0 s, 7 samples)
Process Creation                              43106.5 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  17576.2 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   2575.6 lpm   (60.0 s, 2 samples)
System Call Overhead                        2524241.2 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   55429923.1   4749.8
Double-Precision Whetstone                       55.0      11478.2   2086.9
Execl Throughput                                 43.0      13854.9   3222.1
File Copy 1024 bufsize 2000 maxblocks          3960.0     136810.4    345.5
File Copy 256 bufsize 500 maxblocks            1655.0      41399.6    250.1
File Copy 4096 bufsize 8000 maxblocks          5800.0     329302.8    567.8
Pipe Throughput                               12440.0    3796219.4   3051.6
Pipe-based Context Switching                   4000.0    1231507.4   3078.8
Process Creation                                126.0      43106.5   3421.1
Shell Scripts (1 concurrent)                     42.4      17576.2   4145.3
Shell Scripts (8 concurrent)                      6.0       2575.6   4292.7
System Call Overhead                          15000.0    2524241.2   1682.8
System Benchmarks Index Score                                        1840.2
Q8系列四核的独服,4G内存  这个分算高还是低呢,用的小夜常用的那个测试的。
发表于 2011-1-5 07:47:16 | 只看该作者
浮云。
发表于 2011-1-5 08:59:09 | 只看该作者
这分数比我一个VPS低。但是同意沙发位置的斑竹:浮云啊,浮云
发表于 2011-1-5 09:27:28 | 只看该作者
原帖由 cnx 于 2011-1-5 07:47 发表
浮云。
发表于 2011-1-5 09:35:51 | 只看该作者
浮云。
发表于 2011-1-5 09:41:07 | 只看该作者
独服跑分是有意义的。
跑分的时候把io去掉,否则多进程的分比单进程还低。
发表于 2011-1-5 09:44:43 | 只看该作者
浮云。
发表于 2011-1-5 10:23:33 | 只看该作者
测试啥啊,测试专用机?
 楼主| 发表于 2011-1-5 10:49:09 | 只看该作者
回复 8# 的帖子
想试试多个cpu下 的跑分
GMT+8, 2026-4-20 14:28 , Processed in 0.061795 second(s), 10 queries , Gzip On, MemCache On.
