查看: 3612|回复: 1
capnel空间安装帝国,微擎都报错,mariadb错误怎么发tk,
发表于 2018-2-20 00:33:54 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
建立数据表: phome_enewsad 完毕......
You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'TYPE=MYISAM' at line 1
CREATE TABLE `phome_enewsad` ( `adid` int(10) unsigned NOT NULL auto_increment, `picurl` varchar(255) NOT NULL default '',
我开始发了tk说mysql版本不对,螳螂回复说让我联系源码开发者,我擦,这个怎么和他周旋
GMT+8, 2026-4-29 00:50 , Processed in 0.053621 second(s), 9 queries , Gzip On, MemCache On.
