查看: 2232|回复: 1
linode,折腾一上午无法putty登录SSH,无法ping到vps主机
发表于 2018-2-16 17:19:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
开始怀疑是否ip被墙了,上网一搜索好家伙这么一大片。没辙,先开始玩命删除再重建,换了一堆ip地址,统统time out。
没辙了,开始support写信客服要求换ip。刚回复了,说linode意识到中国高墙**,自己只是干vps的;
ss,ssR这类应用建议自己解决,最近不会考虑换ip了。搓火...附上截图。 无法传图。传文字。
ss,ssR这类应用建议自己解决,最近不会考虑换ip了。搓火...附上截图。无法传图,直接转文字了。
Hey there
I'm really sorry for the issues you are experiencing.  I understand your frustration.  Previously, our team has attempted to swap the IP addresses of Linodes impacted by China’s Great Firewall (高墙).
With the recent developments in the 高墙, our team has determined the swapping of IP addresses is ineffective in resolving the connectivity issues our customers face. The 高墙 will continue to block your IP address shortly after your Linode’s IP has been swapped. At this time, we are no longer swapping IP addresses for Linodes impacted by the 高墙. We also will not be able to resolve this by adding additional IP addresses.
As we have noticed that this is mainly affecting 扶墙 and proxy users, our recommendation for customers impacted by the 高墙 is to investigate different proxy and 扶墙 options for their Linode. It’s important to understand that some users have experienced 高墙 filtering for specific types of proxies on their Linode. While one proxy may not work for a user, another proxy or 扶墙 may still be accessible. If you have an existing proxy, you may want to try switching ports or use UDP. Below we’ve provided some links to common proxy and 扶墙 software that could serve as alternatives.
*It’s important to note that some users have found that basic 扶墙 and proxy connections (such as Shadowsocks, Open扶墙 and the options provided by Streisand) are still actively filtered by the 高墙. In this case, if the services above don’t work for you, you may want to consider working with some of the specialized services configured to specifically address the difficulties of the 高墙.
Common services:
Shadowsocks -
 楼主| 发表于 2018-2-16 17:21:47 | 只看该作者
|                                      WinMTR statistics                                   |
|                       Host              -   %  | Sent | Recv | Best | Avrg | Wrst | Last |
|                                   R8000 -    0 |  187 |  187 |    0 |    0 |    0 |    0 |
|                           111.193.***.* -    0 |  187 |  187 |    0 |   32 |  285 |  285 |
|                           61.148.174.97 -    0 |  187 |  187 |    1 |    2 |    5 |    3 |
|                            61.51.169.65 -    0 |  187 |  187 |    1 |    2 |    7 |    4 |
|                           124.65.194.89 -    1 |  183 |  182 |    2 |    3 |   29 |    2 |
|                           219.158.4.174 -    0 |  187 |  187 |    2 |    6 |   33 |    5 |
|                           219.158.16.66 -    2 |  179 |  177 |    3 |    6 |   13 |    3 |
|                           219.158.96.26 -    0 |  187 |  187 |  149 |  155 |  209 |  151 |
|                  las-bb1-link.telia.net -    0 |  187 |  187 |  146 |  156 |  205 |  152 |
|                  dls-b22-link.telia.net -    1 |  183 |  182 |  186 |  190 |  211 |  198 |
|    linode-ic-321020-dls-b22.c.telia.net -    0 |  187 |  187 |  234 |  259 |  302 |  266 |
|                   No response from host -  100 |   38 |    0 |    0 |    0 |    0 |    0 |
|________________________________________________|______|______|______|______|______|______|
   WinMTR v0.92 GPL V2 by Appnor MSP - Fully Managed Hosting & Cloud Provider
GMT+8, 2026-4-29 03:03 , Processed in 0.062042 second(s), 10 queries , Gzip On, MemCache On.
