查看: 42942|回复: 24
法国ovh欧洲电信直连测试
发表于 2011-1-4 02:43:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
测试IP: 94.23.241.124
下载测试: http://fr01.diavps.com/100mb.zip
电信 outbound tracert:
traceroute to 222.76.217.225 (222.76.217.225), 30 hops max, 40 byte packets
1  vss-2-6k.fr.eu (94.23.241.254)  60.824 ms * *
2  gsw-2-6k.fr.eu (91.121.131.38)  3.744 ms * *
3  gblx.as3549.fr.eu (213.186.32.249)  4.842 ms  4.900 ms  4.948 ms
4  GM-FF-FRK-F-1.163.chinatelecomeurope.com (80.81.194.33)  23.929 ms  23.926 ms  23.933 ms
5  202.97.52.49 (202.97.52.49)  274.923 ms  274.931 ms  274.929 ms
6  202.97.60.21 (202.97.60.21)  275.594 ms  275.461 ms  276.281 ms
7  202.97.60.157 (202.97.60.157)  275.477 ms  275.468 ms  275.128 ms
8   (202.97.33.125)  245.963 ms  246.027 ms  246.639 ms
9   (202.97.41.145)  255.663 ms  255.663 ms  253.982 ms
10  222.76.220.10 (222.76.220.10)  284.131 ms  284.163 ms *
11  222.76.220.118 (222.76.220.118)  255.893 ms  255.265 ms  255.335 ms
12  222.76.217.225 (222.76.217.225)  256.746 ms  257.977 ms  257.819 ms
网通outbount tracert:
traceroute to 210.21.119.139 (210.21.119.139), 30 hops max, 40 byte packets
1  vss-2-6k.fr.eu (94.23.241.254)  21.386 ms * *
2  * * *
3  tata.as6453.fr.eu (213.251.130.50)  4.177 ms  4.286 ms  4.396 ms
4  if-0-1-0-0.tcore1.PYE-Paris.as6453.net (80.231.154.29)  161.083 ms  161.064 ms  161.300 ms
5  if-9-0-0-1817.mcore5.NYY-NewYork.as6453.net (64.86.71.21)  83.054 ms  83.487 ms  83.486 ms
6  if-6-0-0-1824.mcore4.PDI-PaloAlto.as6453.net (207.45.196.77)  151.453 ms  151.418 ms  151.335 ms
7  if-0-0-0.core3.SQN-SanJose.as6453.net (216.6.33.5)  154.689 ms  154.627 ms  154.571 ms
8  ix-3-2.core3.SQN-SanJose.as6453.net (216.6.33.22)  163.790 ms  163.793 ms  163.796 ms
9  219.158.30.161 (219.158.30.161)  311.760 ms  311.760 ms  311.932 ms
10  219.158.11.21 (219.158.11.21)  319.926 ms  319.912 ms  319.714 ms
11  219.158.9.170 (219.158.9.170)  335.768 ms  336.001 ms  335.806 ms
12  120.80.0.130 (120.80.0.130)  323.895 ms  323.863 ms  323.808 ms
13  120.80.173.186 (120.80.173.186)  319.765 ms  319.797 ms  319.787 ms
14  cnc-mx.extmail.net (210.21.119.139)  321.378 ms  321.614 ms  320.772 ms
参与人数 1威望 +25 收起 理由
咯拉无米 + 25 精品文章
发表于 2011-1-4 02:49:34 | 只看该作者
电信的很一般,上海电信连欧洲应该 180ms 到 200ms 之间,现在要 400 毫秒以上。请参考:
http://www.webkaka.com/Ping.aspx?url=94.23.241.124&p=sh
发表于 2011-1-4 02:49:38 | 只看该作者
是走telia线路的啊
 楼主| 发表于 2011-1-4 02:51:12 | 只看该作者
原帖由 khto 于 2011-1-4 02:49 发表
是走telia线路的啊
inbound是走telia线路,
outbound是直接走电信欧洲节点
测试一下下载看看
 楼主| 发表于 2011-1-4 02:53:23 | 只看该作者
大部分地区 220ms左右,
少部分地区 400ms左右
220ms对于欧洲线路来说非常好了
 楼主| 发表于 2011-1-4 02:54:23 | 只看该作者
原帖由 vnconfig 于 2011-1-4 02:49 发表
电信到欧洲不可能有180ms吧? 我测试过欧洲很多机房,基本都要300ms+
发表于 2011-1-4 02:55:04 | 只看该作者
上海电信测试 IP:
202.96.209.133
202.96.209.5
222.66.2.10
61.152.208.71
218.1.64.33
发表于 2011-1-4 02:57:07 | 只看该作者
价格比美国都给力,问题是速度and不适合host和vps
 楼主| 发表于 2011-1-4 02:57:34 | 只看该作者
原帖由 vnconfig 于 2011-1-4 02:55 发表
上海电信测试 IP:
202.96.209.133
202.96.209.5
222.66.2.10
61.152.208.71
218.1.64.33
似乎上海电信连接欧洲的出口有点问题,欧洲电信节点直接到上海节点就400ms了
Host                                                        Loss%  Last   Avg  Best  Wrst StDev
1. vss-2-6k.fr.eu                                            4.5%   6.4  13.1   0.3 114.4  26.8
2. gsw-2-6k.fr.eu                                            0.0%   3.7   3.7   3.7   3.8   0.0
3. gblx.as3549.fr.eu                                         0.0%   4.4  17.3   3.8 191.3  43.6
4. GM-FF-FRK-F-1.163.chinatelecomeurope.com                  0.0%  22.6  23.8  22.6  25.6   0.9
5. 202.97.52.61                                              0.0% 389.7 404.9 389.7 424.9   9.7
6. 202.97.53.25                                              0.0% 390.7 405.2 390.1 424.1   9.8
7. 202.97.53.121                                             0.0% 391.8 413.3 388.9 462.8  19.7
8. 202.97.53.29                                              0.0% 394.4 407.0 391.8 425.5  10.5
9. 61.152.86.73                                              0.0% 388.0 407.3 388.0 444.5  13.5
10. 61.152.81.29                                              0.0% 418.5 438.9 418.5 501.5  17.7
11. 124.74.210.194                                            4.8% 389.1 405.0 389.1 422.3   9.8
12. 218.1.4.66                                                0.0% 417.9 435.1 417.9 452.1   9.8
13. 218.1.64.33                                               4.8% 387.5 405.0 387.5 422.3   9.8
发表于 2011-1-4 03:00:35 | 只看该作者
电信过去不错。网通有点高
GMT+8, 2026-5-1 12:43 , Processed in 0.071024 second(s), 12 queries , Gzip On, MemCache On.
