查看: 21879|回复: 39
入手NFPHosting要三思,这家的IP被墙的很厉害 问题已解决,...
发表于 2018-2-5 16:55:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
已更换IP,问题已解决
本人经历:
开机就是被墙的IP,发工单后换了一个,结果还是被墙的IP,再发工单,回复说是本地ISP的问题,他们无法解决,没办法,只能打水漂了,买个教训吧。
Ticket记录:
全部过程:
02/04/2018 (05:07) 我开工单:
Sir, I just rented a vps, but I can not connect with it in China. Could you change IP for me so that I can use it? thank you very much!
IP: xx.xx.xx.xx
02/04/2018 (05:23) 收到回复:
Hi,
We changed your VPS's IP. Kindly check it ---> xx.xx.xx.xx
02/04/2018 (06:04) 我回:
Sir, I'm sorry but this IP address is: "162.218.209.39" I still can not access it. Could you change it again? Thank you very very much!
02/04/2018 (07:10) 等不到回复,我再回:
Sir, I'm sorry but I still can not access the new IP, Please help me change again. Thanks a lot! and Should I open a new ticket?
02/04/2018 (07:11) 再次收到回复:
Hi,
We have the same IP series, This will rectified by your ISP.
我回复:02/05/2018 (01:50)
I just tried to contact the ISP, they told me that China 高墙 blocked some IP addresses, so I can not access it from China. I hope that you can try to change my VPS's IP again. Thank you very much!
收到回复:02/05/2018 (03:12)
Hi,
We are checking your issue further and shall get back to you soon. Thanks for your patience in advance.
Thank you!
再次收到回复:02/06/2018 (12:00)
Hi,
We had changed your vps ip now. Kindly check with given below new ip.
New ip >> 204.xx.xx.xx
Thank you!
提醒一下大家,网上关于这家VPS的IP被墙或开机就被墙的不少,我开机IP和换了新的两个IP都是被墙的,而且不愿意再换了,机子无法使用,提醒准备入手的亲们谨慎考虑,虽然便宜,也钱不是抢来的。
问题已解决:
分析:
优势:便宜、解决问题还是比较积极的;
缺点:主机资源小可以不算缺点,毕竟这个价格嘛!开到被墙IP概率非常高,解决还是要费周折的。
是不是入手大家自己考虑。
发表于 2018-2-5 16:55:49 | 只看该作者
woothosting 家的呢? 你买的哪一款? IP段多少
 楼主| 发表于 2018-2-5 17:00:00 | 只看该作者
woothosting和alpharacks是一家,我之前用的就是alpharacks,squid死活不能用,重装了几个系统都是这样,不知道为什么,暂时还没有其它家的主机遇到这问题。
发表于 2018-2-5 17:01:22 来自手机 | 只看该作者
据说这家和woot,alpha是一家
发表于 2018-2-5 17:02:32 来自手机 | 只看该作者
我有4和6刀的,开出来就墙了一个,tk换了
 楼主| 发表于 2018-2-5 17:03:03 | 只看该作者
fengshu 发表于 2018-2-5 17:01
据说这家和woot,alpha是一家
NFPHosting和woot, alpha都是一家?
发表于 2018-2-5 17:06:13 | 只看该作者
你看看我签名中间的IP 就是nfp家的 换了好几次才换到
 楼主| 发表于 2018-2-5 17:07:19 | 只看该作者
中奖率的确高,其它网站上也看到有人反映
 楼主| 发表于 2018-2-5 17:08:50 | 只看该作者
原始是:155.94.177.227
换的是:162.218.209.39
都是被墙的。
发表于 2018-2-5 17:10:24 | 只看该作者
z_zt 发表于 2018-2-5 17:08
原始是:155.94.177.227
换的是:162.218.209.39
都是被墙的。
准备搞一台woothosting 6刀试试
GMT+8, 2026-4-26 13:24 , Processed in 0.069684 second(s), 10 queries , Gzip On, MemCache On.
