CeraNetworks网络延迟测速工具IP归属甄别
查看: 9511|回复: 29
出租的一台Online独立服务器被人用来发垃圾邮件 怎么办?
发表于 2018-1-25 19:22:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
怎么办? 实话实说吗?
ONLINE SAS
Technical assistance
BP 438 - 75366 Paris CEDEX 08
France
Tel: 01 84 13 00 00
Dear Sir or Madam,
Our services have received a security alert for your server ip address 163.172.XX.XXX, because of a spam issue.
This alert is followed up by our abuse team with this reference A-202086.
You will find all the details regarding this alert at the end of this email, and in your console by following this url:
https://console.online.net/fr/account/abuse/202086
We would like to remember you that accordingly to our terms and conditions, you will need to correct the problem within 48 hours, and to answer the alert in your console/API.
Otherwise your server ip address 163.172.XX.XXX will be suspended, and you will have to get in touch with our support team to unlock it.
If you don't know how to correct the problem, you can contact our outsourcing partners:
http://www.online.net/en/dedicated-server/dedicated-server-outsourcing
Please connect to your console to get more informations about this alert. Here are some suggestions to help you to correct it:
* Backup all your server data
* Check for recent file changes
* Check log files on your server
* Check your PHP and cgi files for any backdoors
* Check if any software you use is vulnerable, and update them
* Reinstall you server after backup
* Change passwords of your server
    Security alert details
Good afternoon,
Your Ip address (163.172.XX.XXX) is actually listed on UCEPROTECT
You can check it with the form available on their website : http://www.uceprotect.net/en/rblcheck.php
Thank you to take the necessary action to stop all the spam sending as soon as possible.
Feel free to contact Online.net technical assistance for more information
Online.net Abuse service
发表于 2018-1-26 01:04:35 | 只看该作者
他的客户他负责,你的客户你负责.他是你的客户,那么你的责任只到他为止.
就像ONLINE只找你不找他.
所以啊,他客户什么情况跟你没有关系.让他自己处理.
你把他机器收回就是了.
ONLINE这边既然给你48小时了,也挺好的了,起码没直接删机器删账号
发表于 2018-1-25 19:26:39 | 只看该作者
回覆:fixed
簽個名,搞定
後續行動:回收租出去的機器
发表于 2018-1-25 19:23:38 | 只看该作者
说root密码泄露被人拿去干坏事呗,
发表于 2018-1-25 19:28:22 来自手机 | 只看该作者
解释一下咯,至少有mjj主动发包打别人,发tk装傻就开通了
Too Young Too Simple  发表于 2018-1-26 08:23
发表于 2018-1-25 19:31:27 | 只看该作者
這個是投訴,隨便寫點東西就搞定
但一定要搞定服務器發垃圾郵件問題,否則他會再發多封信過來,直至你搞定為止
最簡單重裝OS
发表于 2018-1-25 19:33:12 来自手机 | 只看该作者
承租人已经违反online tos。无条件收回,并且不予退款。然后tk解释一下。收工!
发表于 2018-1-25 19:34:32 | 只看该作者
没重装也可以说重装完了的
 楼主| 发表于 2018-1-25 19:37:27 | 只看该作者
哎。。。。。。。。。。。
麻痹的,再也不租了,哪怕价格再高也不租,不需要的直接取消.
发出QQ,坛子大佬多的是,自会帮你人肉,长期黑名单 置顶。  发表于 2018-1-25 19:39
发表于 2018-1-25 19:43:18 | 只看该作者
曝光
 楼主| 发表于 2018-1-25 20:00:46 | 只看该作者
客户租了后也是再转租的..
所以公布了也没用...
哎...
GMT+8, 2026-4-19 18:12 , Processed in 0.072829 second(s), 12 queries , Gzip On, MemCache On.
