查看: 7161|回复: 11
[疑问] 怎么把PHP5.2.16升级到5.3.4
发表于 2011-1-2 14:21:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
菜鸟,LNAMP...
因为是菜鸟,所以配置的时候都需要看着别人的配置,因此,别人编译的5.2,我也就只上了5.2的最新版,因为5.3有些许不同,当时没上
不过作为版本控的我,还是决定上5.3.4
请教一下,直接下载再便已安装就好了,还是有特别的步骤 ?
发表于 2011-1-2 14:21:38 | 只看该作者
cd /tmp
mkdir src
cd /tmp/src
yum -y install patch make gcc gcc-c++ gcc-g77 flex bison file
yum -y install libtool libtool-libs autoconf kernel-devel
yum -y install libjpeg libjpeg-devel libpng libpng-devel libpng10 libpng10-devel gd gd-devel
yum -y install freetype freetype-devel libxml2 libxml2-devel zlib zlib-devel
yum -y install glib2 glib2-devel bzip2 bzip2-devel libevent libevent-devel
yum -y install ncurses ncurses-devel curl curl-devel e2fsprogs
yum -y install e2fsprogs-devel krb5 krb5-devel libidn libidn-devel
yum -y install openssl openssl-devel vim-minimal nano sendmail
yum -y install fonts-chinese gettext gettext-devel
yum -y install ncurses-devel
yum -y install gmp-devel pspell-devel
yum -y install unzip
yum install gcc gcc-c++ flex autoconf automake make m4 patch libtool openssl-devel file time mlocate sudo bind-utils -y
yum update -y
wget http://monkey.org/~provos/libevent-2.0.9-rc.tar.gz
tar -xzf libevent-2.0.9-rc.tar.gz
cd libevent-2.0.9-rc
./configure
make && make install
cd /tmp/src
wget http://memcached.googlecode.com/files/memcached-1.4.5.tar.gz
tar -xzf memcached-1.4.5.tar.gz
cd memcached-1.4.5
./configure
cd /tmp/src
wget http://launchpad.net/libmemcache ... mcached-0.44.tar.gz
tar -xzf libmemcached-0.44.tar.gz
cd libmemcached-0.44
./configure
cd /tmp/src
yum install mysql-server -y
rpm -ivh http://repo.webtatic.com/yum/centos/5/`uname -i`/webtatic-release-5-1.noarch.rpm
yum --enablerepo=webtatic install php-devel php php-mysql php-sockets php-process php-pecl-memcache php-pecl-gearman httpd php-mcrypt php-mbstring -y
cd /var/www/html
wget http://sourceforge.net/projects/ ... ges.tar.gz/download
tar -xzf phpMyAdmin-3.3.8.1-all-languages.tar.gz
mv phpMyAdmin-3.3.8.1-all-languages phpmyadmin
cd /root
参与人数 1威望 +10 收起 理由
cnx + 10 我很赞同
发表于 2011-1-2 14:22:04 | 只看该作者
楼下来
 楼主| 发表于 2011-1-2 14:24:42 | 只看该作者
回复 3# 的帖子
你楼上已经来了
发表于 2011-1-2 14:25:44 | 只看该作者
把PHP5.3重新编译到一个新的路径就行了,比如/usr/local/php534,再把php环境变量配置到这个目录就Ok了。
 楼主| 发表于 2011-1-2 14:26:48 | 只看该作者
回复 2# 的帖子
你这分明是安装教程
直接这么干?原来已经安装的全部无视?
发表于 2011-1-2 14:28:03 | 只看该作者
原帖由 wishour 于 2011-1-2 14:26 发表
你这分明是安装教程
直接这么干?原来已经安装的全部无视?
yum --enablerepo=webtatic update -y
 楼主| 发表于 2011-1-2 14:30:44 | 只看该作者
回复 7# 的帖子
谢谢,我立马赶去测试
发表于 2011-1-2 17:52:05 | 只看该作者
 楼主| 发表于 2011-1-2 19:40:36 | 只看该作者
测试结果是,升级未遂,yum升级失败,难道是因为不够新?也不会啊,安装的话会是5.3.4的,因为5.3.3和之前的版本差别比较大,求升级策略,自己编译。非一键,非yum安装
GMT+8, 2026-1-1 15:45 , Processed in 0.197329 second(s), 12 queries , Gzip On, MemCache On.
