查看: 5167|回复: 11
悲剧的linode,还是我的长城宽带悲剧了..
发表于 2010-12-30 21:03:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Microsoft Windows XP [版本 5.1.2600]
(C) 版权所有 1985-2001 Microsoft Corp.
C:\Documents and Settings\Administrator>ping www.securitysmarthome.com -t
Pinging securitysmarthome.com [173.255.218.219] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 173.255.218.219: bytes=32 time=278ms TTL=48
Reply from 173.255.218.219: bytes=32 time=281ms TTL=48
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 173.255.218.219:
    Packets: Sent = 16, Received = 3, Lost = 13 (81% loss),
    Minimum = 278ms, Maximum = 281ms, Average = 279ms
Control-Break
Request timed out.
Request timed out.
    Packets: Sent = 18, Received = 3, Lost = 15 (83% loss),
Control-C
^C
C:\Documents and Settings\Administrator>^Z^Z^Z^Z^Z^X
发表于 2010-12-30 21:05:14 | 只看该作者
C:\Users\Administrator>ping www.securitysmarthome.com -t
正在 Ping securitysmarthome.com [173.255.218.219] 具有 32 字节的数据:
来自 173.255.218.219 的回复: 字节=32 时间=219ms TTL=53
请求超时。
请求超时。
来自 173.255.218.219 的回复: 字节=32 时间=218ms TTL=53
请求超时。
请求超时。
请求超时。
来自 173.255.218.219 的回复: 字节=32 时间=213ms TTL=53
来自 173.255.218.219 的回复: 字节=32 时间=211ms TTL=53
来自 173.255.218.219 的回复: 字节=32 时间=224ms TTL=53
请求超时。
173.255.218.219 的 Ping 统计信息:
    数据包: 已发送 = 12,已接收 = 6,丢失 = 6 (50% 丢失),
往返行程的估计时间(以毫秒为单位):
    最短 = 211ms,最长 = 224ms,平均 = 216ms
Control-C
^C
发表于 2010-12-30 21:09:53 | 只看该作者
发表于 2010-12-30 21:10:05 | 只看该作者
哟西
发表于 2010-12-30 21:11:17 | 只看该作者
C:\Documents and Settings\ >ping www.securitysmarthome.com -t
Reply from 173.255.218.219: bytes=32 time=188ms TTL=52
Reply from 173.255.218.219: bytes=32 time=187ms TTL=52
Reply from 173.255.218.219: bytes=32 time=189ms TTL=52
Reply from 173.255.218.219: bytes=32 time=194ms TTL=52
    Packets: Sent = 19, Received = 19, Lost = 0 (0% loss),
    Minimum = 187ms, Maximum = 194ms, Average = 188ms
Control-C
^C
江苏电信 速度很好...
发表于 2010-12-30 21:15:47 | 只看该作者
联通 HE正在狂抽~...
发表于 2010-12-30 21:21:51 | 只看该作者
同为长宽沦落人啊……
发表于 2010-12-30 21:21:53 | 只看该作者
linode一点也不好~~~相对一些垃圾vps。当然要好点
 楼主| 发表于 2010-12-30 21:23:32 | 只看该作者
悲剧的长宽呀,,,还是电信靠点谱....
发表于 2010-12-30 21:35:18 | 只看该作者
其实都杯具了
GMT+8, 2026-4-16 01:07 , Processed in 0.063599 second(s), 10 queries , Gzip On, MemCache On.
