查看: 6048|回复: 7
看LP是不是不愿意免费给我换IP啊
发表于 2009-9-28 15:55:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我LP的IP被和谐了 按照咱论坛写的 给他写了个信
他给我回个
A technician responded to your ticket with:
Hello, It appears that the shared IP for the server you are on may be blocked by the Firewall of China. Here are options that we can suggest to resolve this issue: 1.) Server move + Dedicated IP - We can offer you a move to one of our LPCP servers and enable a dedicated IP on your account (standard dedicated IP fees of $4.95/month apply). Having a dedicated IP means that your website will have its own IP address and won't be blocked if the shared IP of the server is blocked. A move to an LPCP server is required in order to ensure that mail services continue as the LPCP servers have a dedicated mail server whereas the cPanel servers do not. If you require cPanel hosting, please refer to the Dedicated Server solution below. Please note that the move offered does have limitations as we cannot directly move accounts between the two control panels. Your databases and file will not be transferred as a part of this move, you would need to move these yourself. In addition, all email addresses, parked domains, addon domains, subdomains, ftp account, and mysql users would need to be recreated on the new LPCP account. 2.) Upgrade to a VPS account - VPS accounts have fewer accounts on each server so the likelihood of the server becoming blocked is less. You can learn more about the VPS accounts, including cost, by going to http://www.lunarpages.com/virtual-private-server/ 3.) Upgrade to a Dedicated Server - On this plan, you are the ONLY account on the server, so if you are being blocked, then it is because the nature of content that you are hosting. You can lean more about Dedicated accounts, including cost, by going to http://www.lpdedicated.com/ If you wish to proceed, please indicate which option you would like to pursue. In addition, please provide the following: cPanel or Plesk username or the primary domain on the account: Last 4 digits of the credit card on file: If you can not supply the last 4 digits of the credit card, please provide: cPanel or Plesk username or the primary domain on the account: First and last characters of the password on file: Your full postal mailing address: Telephone number: As well as your acceptance of the charges to be made on your account. Thank you for contacting Lunarpages helpdesk. If you require additional assistance, please do not hesitate to contact us again. Kind Regards, Aon Ngiamphaisan Support@lunarpages.com Support forums - http://www.lunarforums.com Telephone: 1-714-521-8150 , Fax: 1-714-521-8195 24 hour Network Status Line: 1-562-697-8106
翻译了下 1.买独立IP  2.买VPS  3.买服务器
日 就不说给我免费换!!!
发表于 2009-9-29 14:23:36 | 只看该作者
回复 1# 的帖子
看来Lunarpages不给免费换共享IP了。
 楼主| 发表于 2009-9-29 16:18:43 | 只看该作者
看来LP不能用了
发表于 2009-10-22 10:38:49 | 只看该作者
回复 3# 的帖子
最好别买了,共享IP都是被封光了的。
发表于 2009-10-27 09:31:31 | 只看该作者
楼主貌似和我的问题一样!!
发表于 2009-10-27 10:08:01 | 只看该作者
回复 5# 的帖子
lunarpages,现在不是国人的选择,国内不能访问的IP太多了。
发表于 2009-10-27 14:34:27 | 只看该作者
以前优惠的时候买的。
哎。。
无语啊 。。。!
发表于 2009-10-27 18:48:41 | 只看该作者
回复 7# 的帖子
其实,换来换去都是被封的IP,他们的机器的共享IP基本都被封光了。
GMT+8, 2026-4-21 17:50 , Processed in 0.060975 second(s), 10 queries , Gzip On, MemCache On.
