查看: 4448|回复: 3
proxmox ZFS RAID10间歇性不能引导
发表于 2017-10-21 01:14:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
什么鬼?
 楼主| 发表于 2017-10-21 03:49:41 | 只看该作者
手动import可以操作。有时候重启又能引导
 楼主| 发表于 2017-10-21 04:45:34 | 只看该作者
Boot fails and goes into busybox
If booting fails with something like
No pool imported. Manually import the root pool
at the command prompt and then exit.
Hint: try: zpool import -R /rpool -N rpool
is because zfs is invoked too soon (it has happen sometime when connecting a SSD for future ZIL configuration). To prevent it there have been some suggestions in the forum. Try to boot following the suggestions of busybox or searching the forum, and try ONE of the following:
a) edit /etc/default/grub and add "rootdelay=10" at GRUB_CMDLINE_LINUX_DEFAULT (i.e. GRUB_CMDLINE_LINUX_DEFAULT="rootdelay=10 quiet") and then issue a # update-grub
b) edit /etc/default/zfs, set ZFS_INITRD_PRE_MOUNTROOT_SLEEP='4', and then issue a "update-initramfs -k 4.2.6-1-pve -u"
发表于 2017-10-21 10:02:22 来自手机 | 只看该作者
GMT+8, 2026-4-13 14:18 , Processed in 0.059670 second(s), 9 queries , Gzip On, MemCache On.
