查看: 4535|回复: 13
[lighttpd] 好吧。linode帮我换IP了
发表于 2017-10-9 21:19:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
jp2机房,ip被block,发工单,帮我换了
传奇1900 该用户已被删除
发表于 2017-10-9 21:41:43 | 只看该作者
发表于 2017-10-9 21:19:59 | 只看该作者
你工单如何说的,发出来 我也学下!
 楼主| 发表于 2017-10-9 21:22:04 | 只看该作者
KKhost 发表于 2017-10-9 21:19
你工单如何说的,发出来 我也学下!
i can not connect my vps ip address?it looks like be block by china **,can you help me check or change the ip address? thanks
MTR Information
Host Lost Sent Recv Best Avrg Wrst Last
192.168.40.100 ??? ??????????    0  107  107    0    1   70    0
192.168.13.102 ??? ??????????    0  107  107    0    0    0    0
101.230.11.57 ??? ??    0  107  107    0    0    2    0
XXX
英语不是很好,见谅
发表于 2017-10-9 21:26:34 来自手机 | 只看该作者
要是jp1就不会帮你换了。
发表于 2017-10-9 21:27:48 | 只看该作者
萌萌小正太 发表于 2017-10-9 21:26
要是jp1就不会帮你换了。
惨啊
 楼主| 发表于 2017-10-9 21:30:52 | 只看该作者
要是jp1就不会帮你换了。
我也这么觉得。JP1的大佬们工单回复了吗?
发表于 2017-10-9 21:39:04 | 只看该作者
jp1路过 不给换ip
Thanks for contacting Linode. We are unable to swap or add additional IP addresses in this datacenter since we have opened our new Tokyo 2 datacenter, but we would be happy to explain your options.
We suggest cloning your current Linode into a new Linode in our new Tokyo 2 datacenter.  The cloning process allows you to troubleshoot any issues with migrating to the KVM platform if they should arise with minimal downtime, as your production machine is still up and running in its original location. You will also have more time to update DNS records since you will be issued an IP with your new Linode in Tokyo 2.
发表于 2017-10-9 21:43:35 | 只看该作者
jp2机房 没事!!!
发表于 2017-10-10 10:35:26 | 只看该作者
换IP自己换就OK啦。
GMT+8, 2026-4-15 12:02 , Processed in 0.073484 second(s), 10 queries , Gzip On, MemCache On.
