CeraNetworks网络延迟测速工具IP归属甄别
查看: 6966|回复: 26
online的特价7o挂PT被发邮件告知超速793次了,现在怎么解决?
发表于 2017-7-25 16:57:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
之前是限制25M上25M下,现在我已经手动限速到10M上10M下了。那还会不会被官方限速呢?
邮件是上午10点发的,现在才看到。
邮件内容:
Hello,
I contact you to alert you of the way that your using your bandwidth.
If you look your Graph, you will see that your bandwidth are always on the top of it.
Your bandwidth limit is 100 mbps you have exceed it 793 times about server xxxxx(服务器名称).
And we can't allow you to stay at this level, so we have two solutions for you :
1) You stop to use your bandwidth at this level and come back to the normal with different tools example Wondershaper on Debian
2) You take the service Higher bandwidth.
Server > Server List > Manage > Service Level & Options > Higher bandwidth
The higher bandwidth option allows you to use more than your server's  bandwidth limit
and thus benefit from the maximum amount of technicaly achievable bandwidth.
This functionality is subject to technical contrainsts of our infrastructure.
This service is made for servers with high bandwidth usage.
Higher bandwidth - 79.99 € pre-tax /month
If you don't choose any of this possibilities, we will have to slow down your server in the next 24 hours.
At your service,
Regards,
Online Team
发表于 2017-7-25 17:20:59 | 只看该作者
1287329 发表于 2017-7-25 17:13
所以我手动限到80M,就是希望不被官方强制限速。
MB Mb 傻傻分不清楚。
发表于 2017-7-25 16:58:35 | 只看该作者
限制25M 什么鬼...
发表于 2017-7-25 16:58:53 | 只看该作者
限速,你的限速要*8
发表于 2017-7-25 16:58:56 | 只看该作者
你不主动限速才会给你限吧
 楼主| 发表于 2017-7-25 17:10:40 来自手机 | 只看该作者
yfans 发表于 2017-7-25 16:58
限制25M 什么鬼...
看到贴吧好多人都说限25到30M不会被官方强制限速
 楼主| 发表于 2017-7-25 17:12:08 来自手机 | 只看该作者
qiqi13245 发表于 2017-7-25 16:58
限速,你的限速要*8
官方说是100M,那我手动限到80M,就是希望不被官方强制限速。
 楼主| 发表于 2017-7-25 17:13:00 来自手机 | 只看该作者
darksheen 发表于 2017-7-25 16:58
If you don't choose any of this possibilities, we will have to slow down your server in the next 24  ...
 楼主| 发表于 2017-7-25 17:32:18 来自手机 | 只看该作者
wtycn 发表于 2017-7-25 17:20
MB Mb 傻傻分不清楚。
好吧,打错,10MB不就是80Mb么?
 楼主| 发表于 2017-7-25 21:01:22 来自手机 | 只看该作者
求大佬告知,会不会被限速?
GMT+8, 2026-4-30 08:21 , Processed in 0.062863 second(s), 9 queries , Gzip On, MemCache On.
