查看: 1811|回复: 16
0529 DZ经常数据库崩溃
发表于 2017-5-28 09:07:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Vultr 512M JP,用的Kangle,内存是够的,但是问题没找到。
要每次service restart才能解决
太占CPU了啊,问题不知道出在哪里
献上部分日志:
Version: '5.1.73'  socket: '/var/lib/mysql/mysql.sock'  port: 3306  Source distribution
170527 14:06:58 mysqld_safe Number of processes running now: 0
170527 14:06:58 mysqld_safe mysqld restarted
170527 14:06:58  InnoDB: Initializing buffer pool, size = 8.0M
170527 14:06:58  InnoDB: Completed initialization of buffer pool
170527 14:06:58  InnoDB: Started; log sequence number 0 46608
170527 14:06:58 [Note] Event Scheduler: Loaded 0 events
170527 14:06:58 [Note] /usr/libexec/mysqld: ready for connections.
170527 14:36:12 mysqld_safe Number of processes running now: 0
170527 14:36:12 mysqld_safe mysqld restarted
170527 14:36:12  InnoDB: Initializing buffer pool, size = 8.0M
170527 14:36:12  InnoDB: Completed initialization of buffer pool
170527 14:36:12  InnoDB: Started; log sequence number 0 46608
170527 14:36:12 [Note] Event Scheduler: Loaded 0 events
170527 14:36:12 [Note] /usr/libexec/mysqld: ready for connections.
170527 16:04:00 mysqld_safe Number of processes running now: 0
170527 16:04:00 mysqld_safe mysqld restarted
170527 16:04:00  InnoDB: Initializing buffer pool, size = 8.0M
170527 16:04:00  InnoDB: Completed initialization of buffer pool
170527 16:04:00  InnoDB: Started; log sequence number 0 46608
170527 16:04:00 [Note] Event Scheduler: Loaded 0 events
170527 16:04:00 [Note] /usr/libexec/mysqld: ready for connections.
170527 16:19:57 mysqld_safe Number of processes running now: 0
170527 16:19:57 mysqld_safe mysqld restarted
170527 16:19:58  InnoDB: Initializing buffer pool, size = 8.0M
170527 16:19:58  InnoDB: Completed initialization of buffer pool
170527 16:19:58  InnoDB: Started; log sequence number 0 46608
170527 16:19:58 [Note] Event Scheduler: Loaded 0 events
170527 16:19:58 [Note] /usr/libexec/mysqld: ready for connections.
170527 20:18:57 mysqld_safe Number of processes running now: 0
170527 20:18:58 mysqld_safe mysqld restarted
170527 20:18:58  InnoDB: Initializing buffer pool, size = 8.0M
170527 20:18:58  InnoDB: Completed initialization of buffer pool
170527 20:18:58  InnoDB: Started; log sequence number 0 46608
170527 20:19:05 [Note] Event Scheduler: Loaded 0 events
170527 20:19:05 [Note] /usr/libexec/mysqld: ready for connections.
170527 20:19:07 mysqld_safe Number of processes running now: 0
170527 20:19:07 mysqld_safe mysqld restarted
170527 20:19:08  InnoDB: Initializing buffer pool, size = 8.0M
170527 20:19:08  InnoDB: Completed initialization of buffer pool
170527 20:19:08  InnoDB: Started; log sequence number 0 46608
170527 20:19:13 [Note] Event Scheduler: Loaded 0 events
170527 20:19:13 [Note] /usr/libexec/mysqld: ready for connections.
170527 20:19:13 mysqld_safe Number of processes running now: 0
170527 20:19:13 mysqld_safe mysqld restarted
170527 20:19:14  InnoDB: Initializing buffer pool, size = 8.0M
170527 20:19:14  InnoDB: Completed initialization of buffer pool
170527 20:19:14  InnoDB: Started; log sequence number 0 46608
170527 20:19:19 mysqld_safe Number of processes running now: 0
170527 20:19:19 mysqld_safe mysqld restarted
170527 20:19:19  InnoDB: Initializing buffer pool, size = 8.0M
170527 20:19:19  InnoDB: Completed initialization of buffer pool
170527 20:19:20 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
170528 00:59:07 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
170528  0:59:07  InnoDB: Initializing buffer pool, size = 8.0M
170528  0:59:07  InnoDB: Completed initialization of buffer pool
170528  0:59:07  InnoDB: Started; log sequence number 0 46608
170528  0:59:07 [Note] Event Scheduler: Loaded 0 events
170528  0:59:07 [Note] /usr/libexec/mysqld: ready for connections.
发表于 2017-5-28 09:10:21 | 只看该作者
几千万数据?
 楼主| 发表于 2017-5-28 09:12:28 | 只看该作者
几千万数据我为什么还用512:lol
发表于 2017-5-28 10:05:25 | 只看该作者
发帖启用下滑动验证码
发表于 2017-5-28 10:53:59 来自手机 | 只看该作者
Vultr512就算是正常的lnmp也会挂
 楼主| 发表于 2017-5-28 11:11:08 | 只看该作者
但是之前也没挂呀,难道Vultr有buff加成?
发表于 2017-5-28 12:31:24 | 只看该作者
反正我的啥也不放  过一段时间mysql就死了
发表于 2017-5-28 12:42:57 | 只看该作者
kangle问题?
 楼主| 发表于 2017-5-28 12:48:45 | 只看该作者
不会吧,kangle我也没改什么东西,都是默认的
 楼主| 发表于 2017-5-28 14:45:17 | 只看该作者
求大神,刚刚又崩溃了一次
GMT+8, 2026-1-12 14:02 , Processed in 0.070605 second(s), 11 queries , Gzip On, MemCache On.
