查看: 2768|回复: 11
[疑问] 我的VIRMACH将要停止几个小时,转移节点
发表于 2017-5-12 14:26:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The downtime could be up to 9 hours but generally it will be under 3 hours per VM.
The migration will occur on LA - and you will not be migrated to a new location. You will just be migrated to another node in LA.
 楼主| 发表于 2017-5-12 15:17:05 | 只看该作者
看来论坛里就我一个人碰上了啊。。
网站还在运营中,郁闷了。
发表于 2017-5-12 14:54:02 | 只看该作者
全是KVM的啊 OVZ的看来是不搬家了
 楼主| 发表于 2017-5-12 14:31:03 | 只看该作者
多个节点。
Dear valued customer,
We have noticed a compatibility issue on a particular group of nodes with the Intel E5-2620v4 processors and KVM virtualization. We have attempted, and will continue to attempt patches on these nodes, however, the continued reboots have created an unpleasant experience for customers. While we do credit customers for any downtime, we understand why reboots every few weeks may be an extreme inconvenience. We are getting close to resolving the issue, but as a precaution we have decided to migrate the following nodes to stable servers.
The estimated downtime will be around 6~ hours for each node but we will attempt to stagger the migrations so only a portion of the node will be down at a time. We will try our best to ensure that your server's IP does not change.
Buffalo: NYKVM5, NYKVM6, NYKVM7, NYKVM8, NYKVM10
Atlanta: ATLKVM2
Los Angeles: LAKVM2
There are other nodes with this issue, but we are unable to migrate everyone at this time. We do have a new patch that we believe should solve the problem, but if you prefer, please contact us to see if we have room to migrate you individually as well.
The dates for migrations are as follows:
NYKVM5, NYKVM6 - 5/9/2017
NYKVM7, NYKVM8 - 5/10/2017
NYKVM10, LAKVM2 - 5/11/2017
ATLKVM2 - 5/12/2017 (May change, check network status page)
If you have any questions or concerns, would like to be migrated early, or if your node is not listed but you would still like to be migrated, please let us know through our ticket system.
Thanks,
Syed A.
Sr. System Administrator
发表于 2017-5-12 14:27:34 来自手机 | 只看该作者
母鸡买来了。之前可能租用cc的
发表于 2017-5-12 14:27:55 | 只看该作者
是有这个说法,貌似某一个node
发表于 2017-5-12 15:59:21 | 只看该作者
我也收到邮件通知了。
发表于 2017-5-12 16:51:29 | 只看该作者
发表于 2017-5-12 16:54:09 来自手机 | 只看该作者
我两个kvm都无提示!
GMT+8, 2026-1-12 23:16 , Processed in 0.072423 second(s), 10 queries , Gzip On, MemCache On.
