查看: 10034|回复: 17
[Windows VPS] virmach 512vps今天被暂停了,说是高IO
发表于 2017-3-22 10:22:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这个帐号里面其它几个VPS,
如果不去理会它,会不会把整个帐号都关闭了,包括同帐号里面其它VPS都没了呢?
这个512洛杉矶kvm从刚买来就硬盘很卡很慢的,我只放了一个站在上面,流量只有几十个一天,攻击也应该没有的,他们家其它几个不是洛杉矶的1G,2Gram VPS,都没有提示高IO.
英文太渣, 看他们邮件要是回复他们的话,要回1,2,3,4,5,6的问题,
都不知道怎么用英文回,才能表达清楚
下面是邮件内容
Your service has been suspended for using high levels of I/O for the third time in a week.
Previous warnings were sent about this matter.
While you have a dedicated amount of disk alloted to you that you may fully use, we limit the
operations on your disk to a fair share. Your service was recently found to be using high
levels of I/O, again. You must understand that your VPS is a virtual instance running on a
physical server with limited amounts of I/O shared across multiple users, which is why we
have this policy in place. Your service was found to be using an average of 206.29
transactions per second for multiple hours.
Our terms can be found at:
http://virmach.com/terms-conditions/
Please reply to this ticket with the following information so we can handle your abuse report
and see if it's possible to restore your service. Otherwise, your service will remain
suspended indefinitely and may be terminated and your account closed.
SUSPENSION APPEAL FORM
1. What were you running on your service?
2. Have you reviewed our terms of service and understand what is prohibited?
3. What steps will you take to prevent further abuse?
4. Do you know how to monitor your network usage, load, CPU usage, and I/O levels?
5. Have you already paid the administration fee associated with dealing with your abuse?
6. May we access your service and/or reset your service if a problem is found?
Please provide login information to access your service.
发表于 2017-3-22 10:24:46 | 只看该作者
服个软,按他说的来,还有恢复的机会
发表于 2017-3-22 10:24:54 | 只看该作者
正常的,之前我只挂了个SS都给我发邮件停了
发表于 2017-3-22 10:33:04 | 只看该作者
曾经CPU过高被暂停。好像就跑了一个测分的脚本
发表于 2017-3-22 10:40:29 | 只看该作者
google翻译帮到你
发表于 2017-3-22 10:46:47 | 只看该作者
我的装win,被关机,现在换Linux了没提醒了
发表于 2017-3-22 10:57:31 | 只看该作者
这个费用貌似蛮高的
发表于 2017-3-22 11:02:21 | 只看该作者
也被暂停过他给关机了,然后我也没管他
发表于 2017-3-22 11:26:03 | 只看该作者
前几天被停机一次,后面又被暂停一次。按着她下面给的东西填被,然后就给你开通了。。。
是在是没搞什么就ss 加个eb挂机。以前挂了好久没事。
GMT+8, 2026-4-14 19:01 , Processed in 0.117765 second(s), 10 queries , Gzip On, MemCache On.
