查看: 3842|回复: 12
如果看自己的alpharacks是不是亚洲优化路线?
发表于 2017-1-13 16:03:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
前几天买了个 alpharacks 2.99  64m的,刚开始是Fraud,后来发了ticket,就跟我说可以付款了,然后分配了ip 是 204开头的.
公司上海电信 trancroute 是cogentco路线转到quadranet路线
家里上海联通 trancroute 是bboi路线转到quadranet路线
 楼主| 发表于 2017-1-13 16:21:13 | 只看该作者
家里路由:
1  192.168.15.1 (192.168.15.1)  19.773 ms  20.026 ms  19.923 ms
2  58.247.148.1 (58.247.148.1)  23.518 ms  23.512 ms  23.261 ms
3  139.226.199.149 (139.226.199.149)  24.432 ms  24.465 ms  24.823 ms
4  139.226.225.149 (139.226.225.149)  24.310 ms 139.226.210.89 (139.226.210.89)  24.104 ms 139.226.225.149 (139.226.225.149)  24.232 ms
5  219.158.23.118 (219.158.23.118)  103.634 ms 219.158.97.94 (219.158.97.94)  102.479 ms 219.158.23.118 (219.158.23.118)  103.372 ms
6  219.158.97.90 (219.158.97.90)  68.165 ms  48.192 ms  48.516 ms
7  * 219.158.30.242 (219.158.30.242)  354.676 ms  354.460 ms
8  laiix.10ge.lax.bboi.net (198.32.146.59)  381.229 ms  414.384 ms  414.510 ms
9  quadranet-bboi.bboi.net (66.186.192.146)  233.561 ms  233.486 ms  233.704 ms
10  colo-lax9.as8100.net (96.44.180.2)  234.488 ms  235.084 ms  235.576 ms
11  104.129.0.2.static.quadranet.com (104.129.0.2)  250.975 ms  251.812 ms  251.253 ms
12  204.****.static.quadranet.com (204.****)  260.981 ms  262.068 ms  262.027 ms
公司路由:
1  10.241.55.1 (10.241.55.1)  4.953 ms  5.206 ms  5.468 ms
2  10.241.3.2 (10.241.3.2)  0.164 ms  0.167 ms  0.487 ms
3  10.241.3.1 (10.241.3.1)  5.644 ms  5.843 ms  6.047 ms
4  10.241.8.2 (10.241.8.2)  0.462 ms  0.459 ms  0.470 ms
5  10.120.0.3 (10.120.0.3)  144.899 ms  145.193 ms  145.196 ms
6  *****.genericreverse.com (*******)  145.193 ms  145.096 ms  145.076 ms
7  * * *
8  te0-0-1-0.nr11.b006608-1.sjc01.atlas.cogentco.com (38.99.107.161)  149.498 ms  144.709 ms  146.336 ms
9  te0-0-0-1.agr12.sjc01.atlas.cogentco.com (154.24.31.41)  147.224 ms  147.724 ms te0-0-0-1.agr11.sjc01.atlas.cogentco.com (154.24.30.173)  147.218 ms
10  te0-0-0-20.ccr21.sjc01.atlas.cogentco.com (154.54.0.113)  150.120 ms te0-0-0-0.ccr22.sjc01.atlas.cogentco.com (154.54.44.89)  149.270 ms te0-7-0-21.ccr21.sjc01.atlas.cogentco.com (154.54.44.73)  150.109 ms
11  be2160.ccr21.lax01.atlas.cogentco.com (154.54.27.161)  163.688 ms  165.147 ms  165.166 ms
12  be2964.ccr41.lax04.atlas.cogentco.com (154.54.44.78)  166.475 ms be2965.ccr41.lax04.atlas.cogentco.com (154.54.45.2)  166.487 ms  168.843 ms
13  38.104.82.218 (38.104.82.218)  154.816 ms  167.974 ms  166.417 ms
14  colo-lax9.as8100.net (96.44.180.2)  155.618 ms  158.218 ms  158.210 ms
15  104.129.0.2.static.quadranet.com (104.129.0.2)  158.214 ms  159.605 ms  160.592 ms
16  204.*****.static.quadranet.com (204.******)  160.585 ms  160.583 ms  160.600 ms
发表于 2017-1-13 17:34:26 | 只看该作者
发工单问,他说是就是,不是也是;他说不是就不是,是也不是
老司机 该用户已被删除
发表于 2017-1-13 17:47:36 来自手机 | 只看该作者
发表于 2017-1-14 00:25:31 | 只看该作者
现在还能开 64M 的?来个链接看看?
发表于 2017-1-14 09:26:21 | 只看该作者
我比较关心你怎么买到2.99的
发表于 2017-1-14 11:06:17 | 只看该作者
http://test.91yun.org/report.php?id=9c66ef03016d69204e13e09f0303b50c
这是我的5刀年付2ip的,128m,速度很一般
 楼主| 发表于 2017-1-16 11:50:34 | 只看该作者
Cry 发表于 2017-1-14 00:25
现在还能开 64M 的?来个链接看看?
前几天我点击了某个64M的链接发现里面有货,然后我就申请了,后来发现是Fraud不能付款,然后我发了ticket是什么情况,那边帮我就帮我开通了,然后我付了款.
GMT+8, 2026-4-27 06:40 , Processed in 0.069402 second(s), 14 queries , Gzip On, MemCache On.
