查看: 2869|回复: 2
Virtualizor的磁盘问题
发表于 2016-11-30 23:33:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Storage Path
In case of LVM please specify the Volume Group path /dev/VG_NAME
                                该咋办
Filesystem            Size  Used Avail Use% Mounted on
/dev/mapper/vg_host-lv_root
                       50G  4.9G   42G  11% /
tmpfs                  16G     0   16G   0% /dev/shm
/dev/sda1             477M   71M  381M  16% /boot
/dev/mapper/vg_host-lv_home
                      1.8T   68M  1.7T   1% /home
/dev/mapper/vg_host-lv_home输入这个也不行,是卸载才可以吗?
显示  The following errors were found :
Server ID : 0 Error : The Volume Group doesn't exist        卷组不存在
 楼主| 发表于 2016-11-30 23:51:17 来自手机 | 只看该作者
shc 发表于 2016-11-30 23:48
/dev/sda1
这是物理卷,好像是挂逻辑卷,不清楚是要挂载还是不挂载
GMT+8, 2026-4-19 12:48 , Processed in 0.063426 second(s), 11 queries , Gzip On, MemCache On.
