查看: 1902|回复: 4
[疑问] Kloxo的默认域名是什么意思?
发表于 2010-11-6 13:47:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一直没弄明白
发表于 2010-11-6 14:05:05 | 只看该作者
哪个?
 楼主| 发表于 2010-11-6 14:11:19 | 只看该作者
默认域名 for admin
This will set the domain that's considered as the primary domain for this particular account. You can access this domain's document root by going to http://IP/~clientname. To map an ipaddress to a domain, you have to click here , go inside an ipaddress and click on 'configure domain' tab there. If you want to view a domain before the dns is setup, the best way is to create an entry for the domain in your local etc/hosts file. The path for the file on windows is c:/windows/system32/drivers/etc/hosts . Just add an entry like this: 192.168.1.32 domain.com on a separete line, and then you will be able to access the domain by typing it in your browser's url box.
发表于 2010-11-6 14:16:24 | 只看该作者
 楼主| 发表于 2010-11-6 14:20:19 | 只看该作者
回复 4# 的帖子
弄明白了
GMT+8, 2026-1-15 19:41 , Processed in 0.059737 second(s), 8 queries , Gzip On, MemCache On.
