查看: 11607|回复: 27
1.5欧元,onapp,1G内存,10t流量,100g防护,Windows中文版
发表于 2016-11-15 12:26:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1G内存,20G硬盘,5T流量,100G DDoS防御,有加拿大和法国机房,记得选加拿大只要1.5欧元,选法国要1.88欧元。更新:后台已经免费支持Windows 2003 2008 2012中文版.
没aff,这下可以放心点了:
http://dwz.cn/4BzqVY
发表于 2016-11-15 12:30:23 | 只看该作者
打不开。。。。
This site can’t be reached
The connection was reset.
Try:
Checking the connection
Checking the proxy and the firewall
Running Network Diagnostics
ERR_CONNECTION_RESET
ReloadHIDE DETAILS
Check your Internet connection
Check any cables and reboot any routers, modems, or other network devices you may be using.
Allow Chrome to access the network in your firewall or antivirus settings.
If it is already listed as a program allowed to access the network, try removing it from the list and adding it again.
If you use a proxy server…
Check your proxy settings or contact your network administrator to make sure the proxy server is working. If you don't believe you should be using a proxy server: Go to Applications > System Preferences > Network > Advanced > Proxies and deselect any proxies that have been selected.
发表于 2016-11-15 12:30:20 来自手机 | 只看该作者
垃圾Aff大嬸
发表于 2016-11-15 12:30:10 | 只看该作者
还原结果:http://www.zhujiceping.com/19235.html
aff是在那边么?
发表于 2016-11-15 12:26:47 | 只看该作者
好 前排占位
 楼主| 发表于 2016-11-15 12:29:52 | 只看该作者
你的VPS还不卖起来,更待何时?
 楼主| 发表于 2016-11-15 12:36:14 | 只看该作者
aff是在那边么?
我博客帖子真没有这家的aff,商家貌似也没有aff。
 楼主| 发表于 2016-11-15 12:40:16 | 只看该作者
tumbzzc 发表于 2016-11-15 12:36
what??????
一家意大利公司,不知道是不是抽风,搞出来的东西可以打死一片人!
GMT+8, 2026-4-30 02:48 , Processed in 0.114481 second(s), 13 queries , Gzip On, MemCache On.
