查看: 5906|回复: 11
hostmantis够狠 从quadranet直接换到OVH了
发表于 2016-11-15 10:41:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  当时买他家的虚拟主机,就是冲着性价比和quadranet的线路,国内速度不错。现在整个洛杉矶的客户直接给扔到OVH加拿大了,大陆访问得绕欧洲再到北美,卡出翔。用他家reseller卖主机的估计得哭死。
  这种没自己机房的商家就是不靠谱,以后买虚拟主机还是得看中有自己机房的,不会给扔来扔去。
Hello ****,
You are receiving this notification because you have an account located on the server LASRV22.
We have scheduled this server to be migrated on 11/11/2016, therefore we are notifying all clients on that server of the pending migration so you can be aware of the upcoming changes and be prepared.
Why are we migrating that server?
We are migrating for several reasons, but most importantly we are migrating for newer hardware with faster CPU’s (processors), more system RAM (memory) and increased DDoS protection. All of which will improve the hosting performance for your websites.
How long will the migration take?
The length of time until completion depends on the amount of data being transferred, however, typical migrations take approximately 24 hours from start to finish.
Is there anything I need to do?
Once you have received the notification that the migration on this server has completed, you will need to update your nameservers at your registrar.
If you are not using our nameservers and are only pointing to that servers IP, please make sure to update to the new server IP at your registrar, Cloudflare, etc.
I’m a reseller, what do I need to do?
If you are a reseller, you will also need to update the IP addresses for your registered nameservers at your registrar to the new IP addresses.
发表于 2016-11-15 12:07:25 来自手机 | 只看该作者
远离这种商家
发表于 2016-11-15 12:37:19 来自手机 | 只看该作者
坑死了。。我有一个他家的洛杉矶分销,不过很久没用了,打算扔掉。。
发表于 2016-11-15 12:43:51 | 只看该作者
幸好之前退款了;额
发表于 2016-11-15 14:22:49 来自手机 | 只看该作者
上了贼船,自认倒霉吧,骚年
发表于 2016-11-15 14:27:36 | 只看该作者
表弟,大名鼎鼎的螳螂主机商!
 楼主| 发表于 2016-11-15 17:44:17 | 只看该作者
狗小二 发表于 2016-11-15 12:43
幸好之前退款了;额
怎么退的款
发表于 2016-11-15 17:49:47 | 只看该作者
跟他们协商要求补偿,维护自己的权益
发表于 2016-11-15 18:52:59 | 只看该作者
你退款也不影响AFFMAN已经到手的推介费
GMT+8, 2026-5-2 07:41 , Processed in 0.308001 second(s), 12 queries , Gzip On, MemCache On.
