查看: 3505|回复: 8
vultr新加坡小鸡小测试一下
发表于 2016-9-17 12:47:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
vultr新加坡节点基本的配置与基础网络测试
本地路由追踪
ping简单测试
vultr拥有大量的IP库,现在多数开的新加坡节点IP是由日本IP广播过去的,具体的要通过路由走向来进行判断,很多IP库都没有更新的。
IO测试
[root@vultr ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 2.65306 s, 101 MB/s
[root@vultr ~]# dd if=/dev/zero of=test bs=8k count=256k conv=fdatasync
262144+0 records in
262144+0 records out
2147483648 bytes (2.1 GB) copied, 4.64886 s, 462 MB/s
UnixBench跑分
BYTE UNIX Benchmarks (Version 5.1.3)
System: vultr.guest: GNU/Linux
OS: GNU/Linux -- 2.6.32-642.4.2.el6.x86_64 -- #1 SMP Tue Aug 23 19:58:13 UTC 2016
Machine: x86_64 (x86_64)
Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
CPU 0: Virtual CPU a7769a6388d5 (4800.0 bogomips)
x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
23:26:53 up 11 min, 1 user, load average: 0.15, 0.04, 0.01; runlevel 3
Benchmark Run: Fri Sep 16 2016 23:26:53 - 23:55:10
1 CPU in system; running 1 parallel copy of tests
Dhrystone 2 using register variables 40392037.7 lps (10.0 s, 7 samples)
Double-Precision Whetstone 4147.6 MWIPS (11.6 s, 7 samples)
Execl Throughput 6441.7 lps (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks 1462120.8 KBps (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks 393503.4 KBps (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks 4637274.7 KBps (30.0 s, 2 samples)
Pipe Throughput 2782696.9 lps (10.0 s, 7 samples)
Pipe-based Context Switching 516354.9 lps (10.0 s, 7 samples)
Process Creation 17264.8 lps (30.0 s, 2 samples)
Shell Scripts (1 concurrent) 7273.8 lpm (60.0 s, 2 samples)
Shell Scripts (8 concurrent) 985.9 lpm (60.0 s, 2 samples)
System Call Overhead 5366904.3 lps (10.0 s, 7 samples)
System Benchmarks Index Values BASELINE RESULT INDEX
Dhrystone 2 using register variables 116700.0 40392037.7 3461.2
Double-Precision Whetstone 55.0 4147.6 754.1
Execl Throughput 43.0 6441.7 1498.1
File Copy 1024 bufsize 2000 maxblocks 3960.0 1462120.8 3692.2
File Copy 256 bufsize 500 maxblocks 1655.0 393503.4 2377.7
File Copy 4096 bufsize 8000 maxblocks 5800.0 4637274.7 7995.3
Pipe Throughput 12440.0 2782696.9 2236.9
Pipe-based Context Switching 4000.0 516354.9 1290.9
Process Creation 126.0 17264.8 1370.2
Shell Scripts (1 concurrent) 42.4 7273.8 1715.5
Shell Scripts (8 concurrent) 6.0 985.9 1643.2
System Call Overhead 15000.0 5366904.3 3577.9
System Benchmarks Index Score 2170.8
单核这样的成绩还算是不错的了,对于一般的网站来说足够使用了哦!
安装AMH所用时间
******* SSH Dirs *******
WebSite: /home/wwwroot
Nginx: /usr/local/nginx
PHP: /usr/local/php
MySQL: /usr/local/mysql
MySQL-Data: /usr/local/mysql/data
Start time: Sat Sep 17 08:08:53 CST 2016
Completion time: Sat Sep 17 08:18:29 CST 2016 (Use: 9 minute)
More help please visit:http://amysql.com
小站小尾巴:小七博客  https://www.xqblog.com
发表于 2016-9-17 14:01:57 | 只看该作者
唔,好神奇的样子。。。
  1. 7     58 ms     5 ms     3 ms  21.246.65.202.unknown.m1.com.sg [202.65.246.21]
  2. 8    172 ms   171 ms   172 ms  3257.sgw.equinix.com [27.111.228.217]
  3. 9    163 ms   164 ms   163 ms  xe-0-0-0.sin11.ip4.gtt.net [141.136.108.53]
  4. 10   164 ms   163 ms   163 ms  ip4.gtt.net [103.232.18.42]
  5. 11    81 ms    81 ms    81 ms  45.32.96.34
  6. 12     *        *        *     Request timed out.
  7. 13    72 ms    71 ms    71 ms  45.32.105.X
发表于 2016-9-17 15:40:28 | 只看该作者
是45.32.105.73这个IP吗?我这里ping不通~
发表于 2016-9-17 16:35:16 | 只看该作者
机器带宽一如既往的大
发表于 2016-9-17 16:44:54 | 只看该作者
日本 NTT,白送都不要了,烂的一B,而且是全天候的烂
发表于 2016-9-17 17:40:32 | 只看该作者
http://test.91yun.org/report.php?id=94bd2c6db3f75d34c2cc2e2bc9b7e1d1
发表于 2016-9-19 08:41:37 | 只看该作者
绕了半个地球  还不错
GMT+8, 2026-4-15 15:29 , Processed in 0.080621 second(s), 15 queries , Gzip On, MemCache On.
