查看: 2750|回复: 7
X3430 的U显示4颗心都为1200MHZ 正常不
发表于 2010-10-31 02:49:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
跑了下分 有2500分 正常不 那3220的机器都显示满频的
Processor Name        Intel(R) Xeon(R) CPU X3430 @ 2.40GHz
Vendor ID        GenuineIntel
Processor Speed (MHz)        1200.000
Benchmark Run: 六 10月 30 2010 10:10:11 - 10:38:23
4 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       15769114.8 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     3145.3 MWIPS (9.9 s, 7 samples)
Execl Throughput                               3602.9 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        688720.3 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          189383.0 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1525101.4 KBps  (30.0 s, 2 samples)
Pipe Throughput                             1183192.4 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 198531.0 lps   (10.0 s, 7 samples)
Process Creation                               9641.1 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   4083.0 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   2659.8 lpm   (60.0 s, 2 samples)
System Call Overhead                         978945.2 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   15769114.8   1351.3
Double-Precision Whetstone                       55.0       3145.3    571.9
Execl Throughput                                 43.0       3602.9    837.9
File Copy 1024 bufsize 2000 maxblocks          3960.0     688720.3   1739.2
File Copy 256 bufsize 500 maxblocks            1655.0     189383.0   1144.3
File Copy 4096 bufsize 8000 maxblocks          5800.0    1525101.4   2629.5
Pipe Throughput                               12440.0    1183192.4    951.1
Pipe-based Context Switching                   4000.0     198531.0    496.3
Process Creation                                126.0       9641.1    765.2
Shell Scripts (1 concurrent)                     42.4       4083.0    963.0
Shell Scripts (8 concurrent)                      6.0       2659.8   4433.0
System Call Overhead                          15000.0     978945.2    652.6
System Benchmarks Index Score                                        1107.6
Benchmark Run: 六 10月 30 2010 10:38:23 - 11:06:39
4 CPUs in system; running 4 parallel copies of tests
Dhrystone 2 using register variables       58549470.8 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                    11570.4 MWIPS (9.9 s, 7 samples)
Execl Throughput                              19891.1 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        208315.6 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           59288.7 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        683833.5 KBps  (30.0 s, 2 samples)
Pipe Throughput                             4410361.3 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                1440073.8 lps   (10.0 s, 7 samples)
Process Creation                              62221.4 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  28151.5 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   3672.7 lpm   (60.1 s, 2 samples)
System Call Overhead                        3425779.8 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   58549470.8   5017.1
Double-Precision Whetstone                       55.0      11570.4   2103.7
Execl Throughput                                 43.0      19891.1   4625.8
File Copy 1024 bufsize 2000 maxblocks          3960.0     208315.6    526.0
File Copy 256 bufsize 500 maxblocks            1655.0      59288.7    358.2
File Copy 4096 bufsize 8000 maxblocks          5800.0     683833.5   1179.0
Pipe Throughput                               12440.0    4410361.3   3545.3
Pipe-based Context Switching                   4000.0    1440073.8   3600.2
Process Creation                                126.0      62221.4   4938.2
Shell Scripts (1 concurrent)                     42.4      28151.5   6639.5
Shell Scripts (8 concurrent)                      6.0       3672.7   6121.2
System Call Overhead                          15000.0    3425779.8   2283.9
System Benchmarks Index Score                                        2513.1
发表于 2010-10-31 02:53:52 | 只看该作者
是独立服务器么?
Intel的CPU一般都有speedstep
在空闲状态下降低频率来降低功耗.
当负载高了它会自动提升频率.
所以一般来说是正常的. 只要负载高了它会自动提升回去就对了.
当然不排除BIOS里设置错了把CPU强行降频了
发表于 2010-10-31 02:56:27 | 只看该作者
 楼主| 发表于 2010-10-31 03:01:46 | 只看该作者
打包的时候也不会全部到2.4G
发表于 2010-10-31 03:06:43 | 只看该作者
那是否提升了?
打包很多时候是需要硬盘IO而不是CPU
 楼主| 发表于 2010-10-31 03:11:28 | 只看该作者
原帖由 domin 于 2010-10-31 03:06 发表
那是否提升了?
打包很多时候是需要硬盘IO而不是CPU
那跑分测试的时候呢? 也只偶尔出现全部2.4G
大多是1-2个核心到2.4G
发表于 2010-10-31 03:15:47 | 只看该作者
跑分的时候你可以再开一个SSH看cpuinfo
发表于 2010-10-31 13:37:31 | 只看该作者
让机房在BIOS里面改一下那啥自动降频的功能。。
GMT+8, 2026-1-15 19:42 , Processed in 0.057563 second(s), 7 queries , Gzip On, MemCache On.
