查看: 9754|回复: 20
OPENVZ+OPENVPN啊!!!
发表于 2009-9-8 16:44:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在网上找到一些相关资料,不过好像我们没有权限进行相关操作.
6.在 vi /etc/vz/vz.conf 里找到
## IPv4 iptables kernel modules
IPTABLES="iptable_nat ipt_REJECT ipt_tos ipt_limit ipt_multiport iptable_filter iptable_mangle ipt_TCPMSS ipt_tcpmss ipt_ttl ipt_length"
将这里的模块加到   vi /etc/vz/conf/120.conf
# CPU fair sheduler parameter
CPUUNITS="1000"
VE_ROOT="/vz/root/$VEID"
VE_PRIVATE="/vz/private/$VEID"
OSTEMPLATE="centos-4-i386-default"
ORIGIN_SAMPLE="vps.basic"
IP_ADDRESS="61.191.20.26"
HOSTNAME="vps120"
NAMESERVER="202.102.192.68"
DEVICES="c:10:200:rw "
IPTABLES="ip_tables iptable_nat iptable_filter iptable_mangle ipt_limit ipt_REJECT ipt_length "
CAPABILITY="NET_ADMINn "
否则会报 nat  filter模块不存在需要重新编译内核。
再执行vzctl set 120 --iptables iptable_filter --iptables ipt_length --iptables ipt_limit --iptables iptable_mangle --iptables ipt_REJECT --save
重启openvz 宿机。
最后在iptables里开 NAT
iptables -t nat -A POSTROUTING -s 10.8.0.0/24  -j SNAT --to-source 61.191.20.26
我就卡在这一步了.拷!
发表于 2009-9-8 16:57:43 | 只看该作者
回复 1# 的帖子
内核的话还得找服务器管理员了。
 楼主| 发表于 2009-9-8 17:00:14 | 只看该作者
他要我在本地先正功运行过再找他.
看来得找些E文文章给他看算了
发表于 2009-9-8 17:04:33 | 只看该作者
回复 3# 的帖子
  把证据提供上去
 楼主| 发表于 2009-9-8 17:16:25 | 只看该作者
PhotonVPS + openVZ + openVPN = lots of fun :)
First the good news,
hopefully soon my "PhotonVPS" odyssey should end and they should be rdy now to setup openVZ + openVPN properly yay!
Here is a small setup review:
Day1: ordered a openVZ VPS and noted in the order "I need iptables + TUN device enabled to run openVPN"
some hours later
PhotonVPS: "Your VPS is rdy!"
Me: "Yay this was fast! Lets test the "speedy" connection!"
Me: "Um iptables has no NAT support and there is no /dev/net/tun device"
Support Mail(1): "iptables nat is missing and TUN also, pls fix"
PhotonVPS: "TUN is enabled now and iptables works fine!"
Me: "Yay finally!"
Support Mail(2): "iptables NAT is still missing and TUN also?"
PhotonVPS: "You must use SNAT in your iptables NAT rule, because Masquerading is not possible with the current Virtuozzo version since it has not been virtualized as a module yet."
Support Mail(3): "Im not sure how to do IP MASQUERADE with just SNAT and without MASQUERADE module, pls explain this to me"
PhotonVPS: "Forwarded to Level3 support"
some time next day
PhotonVPS (L3): "I loaded the MASQUERADE module. Pls try again."
Support Mail(4): "TUN device is still missing, maybe i should try a XEN vps is this setup is not possible?"
PhotonVPS: "NAT is now working correctly!"
Me after a reboot:
Support Mail(5): "iptables: No chain/target/match by that name and the /dev/net/tun device is gone again"
some time later
PhotonVPS: "The TUN device is there, whats your problem with the iptables?"
Support Mail(6): "iptables: No chain/target/match by that name and the /dev/net/tun device is gone again"
(Sidenote, why do i have to explain the error 2 times here?)
PhotonVPS: "Those MASQUERADE issue and the tun should be fixed. Pls run some tests."
Support Mail(6+7) are just some chat that i cant test atm since im working.
Support Mail(8): "… my root dir looks really strange and there are some /20 /100 dirs now that i did not created. Also after reboot /dev/net/tun is gone again, but yay NAT stayed and worked."
Support Mail(9-11): Just some questions about XEN and if its possible to move me to those machines since i can compile my own kernel.
PhotonVPS: They try to setup a script to keep the TUN from from vanishing.
tobe continued
BTW we are at day 3 after order.
While im writing this im still smiling and "hope" they will get it working. Im not really angry atm, no clue why :p
As a sidenode, myprohost needed 1 mail and 15mins to activate iptables + TUN for my openVPN server :p
Tobe fair i will do a speed review if they manage to finally set this up correctly.
 楼主| 发表于 2009-9-8 17:16:43 | 只看该作者
情况跟他的差不多
发表于 2009-9-8 17:18:32 | 只看该作者
回复 5# 的帖子
技术还是挺积极的看得出来。
 楼主| 发表于 2009-9-8 21:42:34 | 只看该作者
终于配置好了!
 楼主| 发表于 2009-9-8 21:42:50 | 只看该作者
要用SNAT.
发表于 2009-9-8 22:32:49 | 只看该作者
原帖由 tim009 于 2009-9-8 21:42 发表
要用SNAT.
何解?
啥时候出正式教程,教教我等
GMT+8, 2026-4-23 02:21 , Processed in 0.063264 second(s), 9 queries , Gzip On, MemCache On.
