查看: 6318|回复: 16
CTL.IO 各机房网络测试汇总
发表于 2016-9-3 15:49:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
悉尼
  1. ----------------------------------------------------------------------
  2. CPU model            : Intel(R) Xeon(R) CPU E5-2650 v3 @ 2.30GHz
  3. Number of cores      : 1
  4. CPU frequency        : 2294.686 MHz
  5. Total amount of ram  : 999 MB
  6. Total amount of swap : 2047 MB
  7. System uptime        : 0days, 15:53:0
  8. Load average         : 0.00, 0.01, 0.02
  9. OS                   : Debian GNU/Linux 7
  10. Arch                 : x86_64 (64 Bit)
  11. Kernel               : 3.2.0-4-amd64
  12. ----------------------------------------------------------------------
  13. Node Name                        IPv4 address                Download Speed
  14. CacheFly                        205.234.175.175                91.8MB/s
  15. Linode, Tokyo, JP                106.187.96.148                2.66MB/s
  16. Linode, Singapore, SG                139.162.23.4                4.38MB/s
  17. Linode, London, UK                176.58.107.39                37.9KB/s
  18. Linode, Frankfurt, DE                139.162.130.8                34.3KB/s
  19. Linode, Fremont, CA                50.116.14.9                2.49MB/s
  20. Softlayer, Dallas, TX                173.192.68.18                1.86MB/s
  21. Softlayer, Seattle, WA                67.228.112.250                2.08MB/s
  22. Softlayer, Frankfurt, DE        159.122.69.4                1.46MB/s
  23. Softlayer, Singapore, SG        119.81.28.170                225KB/s
  24. Softlayer, HongKong, CN                119.81.130.170                2.86MB/s
  25. ----------------------------------------------------------------------
  26. I/O speed(1st run) : 382 MB/s
  27. I/O speed(2nd run) : 380 MB/s
  28. I/O speed(3rd run) : 372 MB/s
  29. Average I/O speed  : 378 MB/s
西雅图
  2. CPU model            : Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz
  4. CPU frequency        : 2600.000 MHz
  7. System uptime        : 0days, 0:13:54
  8. Load average         : 0.00, 0.01, 0.01
  14. CacheFly                        205.234.175.175                110MB/s
  15. Linode, Tokyo, JP                106.187.96.148                3.96MB/s
  16. Linode, Singapore, SG                139.162.23.4                2.36MB/s
  17. Linode, London, UK                176.58.107.39                3.28MB/s
  18. Linode, Frankfurt, DE                139.162.130.8                2.82MB/s
  19. Linode, Fremont, CA                50.116.14.9                20.1MB/s
  20. Softlayer, Dallas, TX                173.192.68.18                10.8MB/s
  21. Softlayer, Seattle, WA                67.228.112.250                91.6MB/s
  22. Softlayer, Frankfurt, DE        159.122.69.4                1.63MB/s
  23. Softlayer, Singapore, SG        119.81.28.170                2.99MB/s
  24. Softlayer, HongKong, CN                119.81.130.170                3.13MB/s
  26. I/O speed(1st run) : 219 MB/s
  27. I/O speed(2nd run) : 243 MB/s
  28. I/O speed(3rd run) : 233 MB/s
  29. Average I/O speed  : 231.667 MB/s
圣克拉拉
  4. CPU frequency        : 2593.750 MHz
  7. System uptime        : 0days, 0:7:13
  14. CacheFly                        205.234.175.175                86.5MB/s
  15. Linode, Tokyo, JP                106.187.96.148                4.09MB/s
  16. Linode, Singapore, SG                139.162.23.4                2.37MB/s
  17. Linode, London, UK                176.58.107.39                3.16MB/s
  18. Linode, Frankfurt, DE                139.162.130.8                2.56MB/s
  19. Linode, Fremont, CA                50.116.14.9                112MB/s
  20. Softlayer, Dallas, TX                173.192.68.18                10.6MB/s
  21. Softlayer, Seattle, WA                67.228.112.250                12.3MB/s
  22. Softlayer, Frankfurt, DE        159.122.69.4                2.46MB/s
  23. Softlayer, Singapore, SG        119.81.28.170                2.20MB/s
  24. Softlayer, HongKong, CN                119.81.130.170                2.38MB/s
  26. I/O speed(1st run) : 226 MB/s
  27. I/O speed(2nd run) : 230 MB/s
  28. I/O speed(3rd run) : 202 MB/s
  29. Average I/O speed  : 219.333 MB/s
参与人数 1威望 +10 收起 理由
我是人 + 10 这个可以有。
 楼主| 发表于 2016-9-3 15:55:58 | 只看该作者
国内 联通 wget 测试,考虑到动态路由的影响,从3个连续的国内IP进行测试
悉尼 > 4MB/s
西雅图 > 4MB/s
圣克拉拉 平均不到 100KB/s 最多200多,质量最差,可能跟路由跳点太多有关
综上所述,联通用户西雅图是最合适的
 楼主| 发表于 2016-9-3 16:01:03 | 只看该作者
新加坡联通可以无视了,绕道美国,想好都不可能的
发表于 2016-9-3 16:01:52 | 只看该作者
我最希望看到IP
 楼主| 发表于 2016-9-3 16:05:04 | 只看该作者
local 发表于 2016-9-3 16:01
我最希望看到IP
翻翻之前的帖子 我都贴过好几次了。。。
 楼主| 发表于 2016-9-3 16:09:05 | 只看该作者
freevps.us 测试,西雅图和圣克拉拉基本上完全一致,这两个地点挨得很近,所以只需要考虑到国内路由即可
西雅图
  1. Location                Provider        Speed
  2. CDN                        Cachefly        118MB/s
  3. Atlanta, GA, US                Coloat                6.36MB/s
  4. Dallas, TX, US                Softlayer        10.9MB/s
  5. Seattle, WA, US                Softlayer        103MB/s
  6. San Jose, CA, US        Softlayer        23.4MB/s
  7. Washington, DC, US        Softlayer         6.95MB/s
  8. Tokyo, Japan                Linode                3.70MB/s
  9. Singapore                 Softlayer        2.95MB/s
  10. Rotterdam, Netherlands        id3.net                2.62MB/s
  11. Haarlem, Netherlands        Leaseweb        7.17MB/s
  12. Disk Speed
  13. ----------
  14. I/O (1st run)        : 192 MB/s
  15. I/O (2nd run)        : 178 MB/s
  16. I/O (3rd run)        : 195 MB/s
  17. Average I/O        : 188.333 MB/s
圣克拉拉
  2. CDN                        Cachefly        76.6MB/s
  3. Atlanta, GA, US                Coloat                6.42MB/s
  4. Dallas, TX, US                Softlayer        10.5MB/s
  5. Seattle, WA, US                Softlayer        22.6MB/s
  6. San Jose, CA, US        Softlayer        93.0MB/s
  7. Washington, DC, US        Softlayer         6.13MB/s
  8. Tokyo, Japan                Linode                3.71MB/s
  9. Singapore                 Softlayer        2.39MB/s
  10. Rotterdam, Netherlands        id3.net                2.15MB/s
  12. Disk Speed
  13. ----------
  14. I/O (1st run)        : 238 MB/s
  15. I/O (2nd run)        : 221 MB/s
  16. I/O (3rd run)        : 228 MB/s
  17. Average I/O        : 229 MB/s
发表于 2016-9-3 16:18:14 来自手机 | 只看该作者
发表于 2016-9-3 16:39:25 | 只看该作者
单向绕,还行.
发表于 2016-9-3 16:47:01 | 只看该作者
感觉一般般啊,不是免费不想用
GMT+8, 2026-4-15 05:37 , Processed in 0.082273 second(s), 14 queries , Gzip On, MemCache On.
