查看: 5578|回复: 3
现在 ss 配置用的白名单,但是却完全上不了 Telegram 求带
发表于 2016-8-25 18:33:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ss 白名单用的是 https://github.com/breakwa11/高墙_whitelist 的,理论上用的是白名单,除了一些国内网站别的都走代理,为啥 Telegram 还会上不去呢 ...... 上去一直 连接中
主干部分如下(去掉了几千行的名单),求大神分析:
var wall_proxy = "SOCKS5 127.0.0.1:1080; SOCKS 127.0.0.1:1080;";
var nowall_proxy = "DIRECT;";
var direct = "DIRECT;";
var ip_proxy = "DIRECT;";
var white_domains = {"am":{
"126":1,
"hexun.com":1,
"taiwandao":1
},"us":{
"pangu":1
},"ws":{
"0798":1
},"xn--fiqs8s":{
"":1
var subnetIpRangeList = [
0,1,
167772160,184549376,  //10.0.0.0/8
2886729728,2887778304,  //172.16.0.0/12
3232235520,3232301056,  //192.168.0.0/16
2130706432,2130706688 //127.0.0.0/24
var hasOwnProperty = Object.hasOwnProperty;
function check_ipv4(host) {
  // check if the ipv4 format (TODO: ipv6)
  //   http://home.deds.nl/~aeron/regex/
  var re_ipv4 = /^\d+\.\d+\.\d+\.\d+$/g;
  if (re_ipv4.test(host)) {
    // in theory, we can add chnroutes test here.
    // but that is probably too much an overkill.
    return true;
function convertAddress(ipchars) {
  var bytes = ipchars.split('.');
  var result = (bytes[0] << 24) |
  (bytes[1] << 16) |
  (bytes[2] << 8) |
  (bytes[3]);
  return result >>> 0;
function isInSubnetRange(ipRange, intIp) {
  for ( var i = 0; i < 10; i += 2 ) {
    if ( ipRange[i] <= intIp && intIp < ipRange[i+1] )
      return true;
function getProxyFromDirectIP(strIp) {
  var intIp = convertAddress(strIp);
  if ( isInSubnetRange(subnetIpRangeList, intIp) ) {
    return direct;
  return ip_proxy;
function isInDomains(domain_dict, host) {
  var suffix;
  var pos1 = host.lastIndexOf('.');
  suffix = host.substring(pos1 + 1);
  if (suffix == "cn") {
    return true;
  var domains = domain_dict[suffix];
  if ( domains === undefined ) {
    return false;
  host = host.substring(0, pos1);
  var pos = host.lastIndexOf('.');
  while(1) {
    if (pos <= 0) {
      if (hasOwnProperty.call(domains, host)) {
        return true;
      } else {
        return false;
    suffix = host.substring(pos + 1);
    if (hasOwnProperty.call(domains, suffix)) {
      return true;
    pos = host.lastIndexOf('.', pos - 1);
function FindProxyForURL(url, host) {
  if ( isPlainHostName(host) === true ) {
    return direct;
  if ( check_ipv4(host) === true ) {
    return getProxyFromDirectIP(host);
  if ( isInDomains(white_domains, host) === true ) {
    return nowall_proxy;
  return wall_proxy;
发表于 2016-8-25 18:35:16 | 只看该作者
直接开全局多方便
发表于 2016-8-26 00:54:19 | 只看该作者
这样不就行了。
发表于 2016-8-26 01:09:16 来自手机 | 只看该作者
SOCKS5代理  127.0.0.1不就行了嘛
GMT+8, 2026-4-20 17:54 , Processed in 0.065761 second(s), 10 queries , Gzip On, MemCache On.
