查看: 3516|回复: 9
麻蛋 ,再一次被锁在外面,进不去了!
发表于 2016-8-14 11:38:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
懒省事,下载个3389修改工具,
结果 麻蛋  端口是改了,默认把远程连接给关闭了!
再次请出老死机乐呵呵
好了,发现昨天@雨宫音羽 说的这个
http://lifehacker.com/5584762/edit-the-windows-registry-from-a-linux-thumb-drive
好像是清除密码用的 ,
远程注册表连接不上,不知道哪里出了问题
不过 救援可以挂载 ,貌似可以搞定!
思路 启动文件夹添加启动项,刚好我有设置自动登录。
然后导入reg文件即可。
话说,谁提供一个reg文件过来。 再来个vbs 脚本 !手机党伤不起啊!
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Aug 13 22:52:27 2016 from 10
root@rescue:~# mkdir /media/windows
root@rescue:~# sudo mount /dev/sda2 /media/windows
The disk contains an unclean file system (0, 0).
The file system wasn't safely closed on Windows. Fixing.
root@rescue:~# chntpw -l /media/windows/Windows/system32/config/software
chntpw version 1.00 140201, (c) Petter N Hagen
openHive(/media/windows/Windows/system32/config/software) failed: No such file or directory, trying read-only
openHive(/media/windows/Windows/system32/config/software) in fallback RO-mode failed: No such file or directory
chntpw: Unable to open/read a hive, exiting..
root@rescue:~# umount /dev/sda2
able to locate package ntfs-progs
root@rescue:~# sudo ntfs-3g -o rw /dev/sda2 /media/windows/
root@rescue:~# cd /media/
root@rescue:/media# cd windows/
root@rescue:/media/windows# la
-bash: la: command not found
root@rescue:/media/windows# ls
Documents and Settings  PerfLogs     Program Files        Recovery      System Volume Information  Windows
pagefile.sys            ProgramData  Program Files (x86)  $Recycle.Bin  Users
root@rescue:/media/windows# cd Windows/
root@rescue:/media/windows/Windows# ls
addins                            explorer.exe       ModemLogs          ServiceProfiles       tracing
AppCompat                         Fonts              msdfmap.ini        servicing             twain_32
AppPatch                          fppset.inf         notepad.exe        Setup                 twain_32.dll
assembly                          fveupdate.exe      Offline Web Pages  setupact.log          twain.dll
bfsvc.exe                         Globalization      Panther            setuperr.log          twunk_16.exe
BitLockerDiscoveryVolumeContents  Help               Performance        ShellNew              twunk_32.exe
Boot                              HelpPane.exe       PLA                SoftwareDistribution  Ultimate.xml
bootstat.dat                      hh.exe             PolicyDefinitions  Speech                Vss
Branding                          IME                Prefetch           splwow64.exe          Web
CSC                               inf                regedit.exe        Starter.xml           WindowsShell.Manifest
Cursors                           Installer          Registration       system                WindowsUpdate.log
debug                             L2Schemas          RemotePackages     System32              winhlp32.exe
diagnostics                       LiveKernelReports  rescache           system.ini            win.ini
DigitalLocker                     Logs               Resources          SysWOW64              winsxs
Downloaded Program Files          Media              SchCache           TAPI                  WMSysPr9.prx
ehome                             mib.bin            schemas            Tasks                 write.exe
en-US                             Microsoft.N
发表于 2016-8-14 11:46:49 | 只看该作者
只是忘掉密码的话 参考sethc后门
发表于 2016-8-14 11:48:42 | 只看该作者
传个1.exe  多省事
 楼主| 发表于 2016-8-14 11:51:15 | 只看该作者
funders 发表于 2016-8-14 11:46
只是忘掉密码的话 参考sethc后门
远程连接关了。。。 默认打开 ,软件修改端口 关了
发表于 2016-8-14 12:39:11 | 只看该作者
月痕 发表于 2016-8-14 11:48
传个1.exe  多省事
老司机啊,好熟悉的文件名
发表于 2016-8-14 12:44:38 | 只看该作者
挂一个深度PE清密码然后进系统改回来。。。。。。
 楼主| 发表于 2016-8-14 14:53:00 | 只看该作者
有pe好办了 关键没有
 楼主| 发表于 2016-8-14 15:49:49 | 只看该作者
好了  找个注册表导入进去了,完美解决
发表于 2016-8-14 16:18:51 | 只看该作者
没带钥匙啊
发表于 2016-8-14 16:35:16 | 只看该作者
咋回事 又开始502了。。
GMT+8, 2026-4-16 06:18 , Processed in 0.074454 second(s), 11 queries , Gzip On, MemCache On.
