查看: 6916|回复: 21
[不限流量] 收leaseweb香港
发表于 2016-7-20 17:56:36 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如题。高价手
发表于 2016-7-20 23:17:25 | 只看该作者
无限出5刀op
发表于 2016-7-20 23:46:33 | 只看该作者
5刀可以开哪些地方的?
发表于 2016-7-20 23:59:05 | 只看该作者
Hello,
Plan01 are now available for Hong Kong location depending on available places, but we recommend plan 02 or higher.
Please let us know if we can be of any further assistance,
Regards,
发表于 2016-7-21 00:05:31 | 只看该作者
mypierce 发表于 2016-7-20 23:46
5刀可以开哪些地方的?
如果是之前半价入的5刀PLAN2可以开香港,原价的5刀PLAN1开不了。
发表于 2016-7-21 07:08:07 来自手机 | 只看该作者
jinxin1967 发表于 2016-7-20 23:17
无限出5刀op
能push?
发表于 2016-7-21 16:53:51 | 只看该作者
5刀可以开哪些地方的?
HK
发表于 2016-7-21 16:58:15 | 只看该作者
egoate 发表于 2016-7-20 23:59
Hello,
Plan01 are now available for Hong Kong location depending on available places, but we recomm ...
Hello sir,
Can you confirm what is the error you get when you try to build your VM in this location?
Regards,
Sebastien L.
OneProvider / Support Department
My location: North America
#hypeonecloud---
Hello,
Please confirm the hostname along with the needed OS, we will try to manually create your plan 01.
Regards,
Olivier M.
Hello,
the VM have been created, here are your information:
IP: 27.0.xxx.xx
User: root
Pass: XXXXXXXXXXX
you may kindly let us know if we can provide you any further assistance.
Regards,
Olivier M.
GMT+8, 2026-5-1 09:36 , Processed in 0.070609 second(s), 12 queries , Gzip On, MemCache On.
