CeraNetworks网络延迟测速工具IP归属甄别
查看: 4475|回复: 2
SliceBox今天维护了,部分服务器需要转移更换IP.
发表于 2010-10-14 23:38:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大意是部分服务器65.49.6.x会被转移,预期4-6个小时,48小时之内实施,转移后服务器IP更换,用户将需要通过KVM重新设置自己服务器的IP。
hello everybody.  Continue reading if your server has IP in 65.49.6.x range.
1.  We are in the process of shifting our servers within He.net datacenters to streamline our network.  Please note that only servers with 65.49.6.x  range is under this move.
2. We are expecting this move to be completed within 4 to 6hrs during next 48hrs based on the availability of tech at the Data center.
Once completed we shall open a support ticket with new KVM login Information as well as replacement IP range. At this point we could not restore the actual range and sorry about that. When you have received the support email with new IP info , you will need to reconfigure the IP on your server with new allocation and your server will be online through KVM
发表于 2010-10-15 08:48:02 | 只看该作者
还要自己更换ip?
 楼主| 发表于 2010-10-15 10:08:38 | 只看该作者
嗯,需要自己设置。 用KVM, 国内访问HE线路还可以吧,不然就是杯具了。
GMT+8, 2026-5-1 16:53 , Processed in 0.065667 second(s), 9 queries , Gzip On, MemCache On.
