查看: 1626|回复: 0
求英语翻译下
发表于 2016-4-17 17:53:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Let us know , should we proceed with the reload , as discussed earlier , with 50 G space as per plan that you have.
To fix it , reload would have to be done as per the Billing Plan.
If there is an issue with space , with existing plan , we suggest you to upgrade to some higher plan.
扶墙 would be installed at your end , once the reload / upgrade is completed.
Let us know your views on this.
这段话是什么意思,百度翻译都有点不对,yardvps的不能用了很久了,是以前的旧款,然后我看到现在新的是50G内存,我问过他重装后是不是50G硬盘
GMT+8, 2026-4-28 02:44 , Processed in 0.064954 second(s), 12 queries , Gzip On, MemCache On.
