查看: 4552|回复: 10
谁把以前的老帖锐速php版本设置权限90呢??
发表于 2016-3-6 23:51:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. <?php
  2.
  3. header("Content-Type: text/html;charset=utf-8");
  4. /*
  5. if($argc < 4) {
  6.         echo("Usage: php ". $argv[0] . " mac expireYear bandwidth\nBandwidth=0 means unlimited\n");
  7.         exit;
  8. }
  9. */
  10. $lic_tpl = "b226bc274e220f53e22d863a1ec913dea6961bd046d034e88818e68d260d781345298b8d3b11e00b5061045667c12af4982992ab86ee7a4f84c1ef83020a1adc[serial]c81cb3b404eab69f59993fbf62bd373a[date]0663cea3f326[bw]a366445113ecf74205e40af32cb30c5342cc5ebd981f7e02a9326f3823e8304e4d20f942f20bdfbeaeeff843";
  11. // month/date base: FA43 now 0663 => 1231 we do not change it
  12. $date_base = 16245;
  13. $bw_base = 3812869942;
  14. //$mac = $_GET['mac'];
  15. $mac ='56:00:00:20:59:5d';
  16. //$date = intval($_GET['year']);
  17. $date=2034;
  18. //$bw = intval($_GET['bw']);
  19. $bw =0;
  20. $mac = explode(":", $mac);
  21. $mac_res = array();
  22. for($i = 0; $i < 16; $i ++) {
  23.         if($i < 6) {
  24.                 $mac_res[$i] = intval($mac[$i], 16) + $i;
  25.         } else {
  26.                 $mac_res[$i] = $mac_res[$i%6] + $i;
  27.         }
  28. }
  29. $serial = "";
  30. for($i = 0; $i < 8; $i ++) {
  31.         $serial .= sprintf("%02X", ($mac_res[$i] + $mac_res[$i + 8]) % 256);
  32. }
  33. $lic = "";
  34. $rd = array(162,15,239,202,57,14,45,164,147,232,120,90,117,15,239,232);
  35. for($i = 0; $i < 16; $i ++) {
  36.         $lic .= sprintf("%02x", (ord($serial[$i]) + $rd[$i]) % 256);
  37. }
  38. $date_lic = unpack("H*", pack("v", $date_base + $date));
  39. $date_lic = $date_lic[1];
  40. $bw_lic = unpack("H*", pack("V", $bw_base + $bw));
  41. $bw_lic = $bw_lic[1];
  42. $lic = str_replace('[serial]', $lic, $lic_tpl);
  43. $lic = str_replace('[date]',  $date_lic, $lic);
  44. $lic = str_replace('[bw]',  $bw_lic, $lic);
  45. //@file_put_contents("./apx-20341231.lic.", pack('H*', $lic));
  46. $file_contents= pack('H*', $lic);
  47. $outfile='apx-20341231.lic';
  48. header('Content-type: application/octet-stream; charset=utf8');
  49. Header("Accept-Ranges: bytes");
  50. header('Content-Disposition: attachment; filename='.$outfile);
  51. echo  $file_contents;
  52. exit();
自己修改mac地址即可
发表于 2016-3-6 23:53:05 | 只看该作者
这个有什么用呢?
发表于 2016-3-6 23:54:55 | 只看该作者
这个有什么用呢?
 楼主| 发表于 2016-3-6 23:56:31 | 只看该作者
楼上2位,真的是女人都送床上了,自己不行了
发表于 2016-3-7 00:20:59 来自手机 | 只看该作者
发表于 2016-3-7 00:22:17 | 只看该作者
你的火力集中群怎么查询不到呀?
发表于 2016-3-7 00:26:30 | 只看该作者
序列号是什么规则生成的呢?
发表于 2016-3-7 01:02:07 | 只看该作者
這個可以有
发表于 2016-3-7 08:50:58 | 只看该作者
发表于 2016-3-10 19:36:38 | 只看该作者
感谢感谢感谢
GMT+8, 2026-4-27 14:06 , Processed in 0.062858 second(s), 10 queries , Gzip On, MemCache On.
