CeraNetworks网络延迟测速工具IP归属甄别
查看: 41706|回复: 52
PacificRack服务器 访问荷兰的速度如何?
发表于 2009-9-1 05:55:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发表于 2009-9-1 06:06:08 | 只看该作者
让 Turing 帮你ping 一下
发表于 2009-9-1 07:05:38 | 只看该作者
PING 77.72.169.14 (77.72.169.14) 56(84) bytes of data.
64 bytes from 77.72.169.14: icmp_seq=1 ttl=238 time=216 ms
64 bytes from 77.72.169.14: icmp_seq=2 ttl=238 time=184 ms
64 bytes from 77.72.169.14: icmp_seq=3 ttl=238 time=216 ms
64 bytes from 77.72.169.14: icmp_seq=4 ttl=238 time=151 ms
64 bytes from 77.72.169.14: icmp_seq=5 ttl=238 time=218 ms
64 bytes from 77.72.169.14: icmp_seq=6 ttl=238 time=189 ms
64 bytes from 77.72.169.14: icmp_seq=7 ttl=238 time=216 ms
64 bytes from 77.72.169.14: icmp_seq=8 ttl=238 time=151 ms
64 bytes from 77.72.169.14: icmp_seq=9 ttl=238 time=216 ms
64 bytes from 77.72.169.14: icmp_seq=10 ttl=238 time=187 ms
64 bytes from 77.72.169.14: icmp_seq=11 ttl=238 time=267 ms
64 bytes from 77.72.169.14: icmp_seq=12 ttl=238 time=155 ms
64 bytes from 77.72.169.14: icmp_seq=13 ttl=238 time=196 ms
64 bytes from 77.72.169.14: icmp_seq=14 ttl=238 time=191 ms
64 bytes from 77.72.169.14: icmp_seq=15 ttl=238 time=199 ms
64 bytes from 77.72.169.14: icmp_seq=16 ttl=238 time=159 ms
64 bytes from 77.72.169.14: icmp_seq=17 ttl=238 time=200 ms
64 bytes from 77.72.169.14: icmp_seq=18 ttl=238 time=193 ms
64 bytes from 77.72.169.14: icmp_seq=19 ttl=238 time=199 ms
64 bytes from 77.72.169.14: icmp_seq=20 ttl=238 time=161 ms
64 bytes from 77.72.169.14: icmp_seq=21 ttl=238 time=197 ms
64 bytes from 77.72.169.14: icmp_seq=22 ttl=238 time=196 ms
64 bytes from 77.72.169.14: icmp_seq=23 ttl=238 time=195 ms
64 bytes from 77.72.169.14: icmp_seq=24 ttl=238 time=159 ms
64 bytes from 77.72.169.14: icmp_seq=25 ttl=238 time=200 ms
--- 77.72.169.14 ping statistics ---
25 packets transmitted, 25 received, 0% packet loss, time 23985ms
 楼主| 发表于 2009-9-1 10:24:27 | 只看该作者
发表于 2009-9-1 10:42:22 | 只看该作者
24小时
 楼主| 发表于 2009-9-1 11:11:17 | 只看该作者
发表于 2009-9-1 11:51:23 | 只看该作者
回复 6# 的帖子
发表于 2009-9-1 12:42:07 | 只看该作者
不知道99美圆的E5200 和149美圆的Q9300性能上差距有多大?
发表于 2009-9-1 13:01:10 | 只看该作者
回复 8# 的帖子
PE5200比E6550还差些,虽都属双核。
Q9300相对比较强,四核心架构。
我找下benchmark,仅供参考。
发表于 2009-9-1 13:08:27 | 只看该作者
恩,但价格毕竟相差50美金呢。。。
GMT+8, 2026-4-13 13:10 , Processed in 0.060273 second(s), 9 queries , Gzip On, MemCache On.
