查看: 4559|回复: 3
[Windows VPS] UK2 SSL证书提交域名出现Sorry, it seems you have already requested a c...
发表于 2016-1-20 19:57:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Unfortunately an error occurred whilst processing your request.
Sorry, it seems you have already requested a certificate for the hostname you entered, or for a hostname which also resolves to the same IP(s) as the hostname you entered this time.
Please use your browser's Back button and try again.
之前申请过了?还要和之前解析的那个IP一样才行?
发表于 2016-1-20 20:20:57 | 只看该作者
一个域名+一个ip 限一次
 楼主| 发表于 2016-1-20 20:21:45 | 只看该作者
qweasdzxc123 发表于 2016-1-20 20:20
一个域名+ip 限一次
what the f@ck~~~~~~~~~~~~~~~~~~~~~
发表于 2016-1-20 20:30:27 | 只看该作者
可以换一个ip再试试
GMT+8, 2026-4-17 00:51 , Processed in 0.120895 second(s), 12 queries , Gzip On, MemCache On.
