查看: 2396|回复: 5
恩组草基吧 挂了2天了
发表于 2016-1-13 20:05:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. There was an issue with the disk controller on this node, which has taken it offline. The array rebuild has been completed, however there are file system checks being completed that are taking much longer than expected. We expect everything to be functioning normally again soon. We apologize for the inconvenience and delay.
Physical ServerDC02R02DS12
你们挂几天了?
发表于 2016-1-13 20:29:07 | 只看该作者
发表于 2016-1-13 21:44:31 | 只看该作者
1分钟出现在下面
发表于 2016-1-14 00:04:05 | 只看该作者
昨天收到维护邮件
As a valued customer, Enzu is committed to keeping you informed about any changes in the status of your service with us. This email is to alert you regarding a maintenance we will be performing.
Date: 1/12/2016 9:00 AM to 9:00 PM Pacific
Location of Event: Los Angeles, California
Suite(s): DC08
Type of Event: Infrastructure Enhancement
Expected Downtime: Up to 40 minutes down time (25-30 minutes expected)
Equipment Affected: OpenVZ/Xen Based VPS Services
Description: Engineers will be performing power infrastructure maintenance.
During this window engineers will be disconnecting power and reconfiguring at the cabinet.
Best practice and procedures will be employed throughout this event and we would like to ensure that all relevant IDC tenants are aware of the activity. Again, downtime should not exceed 40 minutes for any tenant during this time.
If you have any questions or concerns about this maintenance advisement, please call or contact the Operations Support Center via the appropriate telephone number or portal.scalabledns.com
发表于 2016-1-14 00:36:39 来自手机 | 只看该作者
就是昨晚维护了一下,没啥情况
GMT+8, 2026-4-16 21:09 , Processed in 0.058500 second(s), 10 queries , Gzip On, MemCache On.
