查看: 7691|回复: 22
UBI服务器大促销最低19美元月付!
发表于 2015-12-23 16:17:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
曾几何时,linode一个1G内存的VPS就要19美元,而现在19美元的独立服务器现在遍地都是,我们来看看UBI给我带来的促销折扣吧~小康选几个特别的给大家分享。
麻烦有空的朋友走我的AFF:https://ubiquityhosting.com/aff/index/36861
WHT Special #1  看点:IP给的很足
Intel Xeon E3-1230 – 4x 3.20GHz, 8MB Cache (v2 and v3 provided when available)
16GB DDR3 ECC RAM
Upgrade to 32 GB for just $20 more.
1TB Enterprise SATA HDD
30TB Monthly Bandwidth (IN+OUT) * Upgrade to 100 TB for just $99 more.
1000 Mbps Public Network Uplink
/24 IPv4 Allocation (253 Usable IP addresses)
DDoS Protected Network
Ubiquity Motion Management Platform
100% Uptime SLA
Choose from 7 Data Centers
Order This! – Priced at $59/month, $0 Setup!
订购地址:https://www.ubiquityhosting.com/dedicated/order/token/c67d4f3bb30b0d1caff6e527a6485a16?utm_source=WHT&utm_medium=sponpost&utm_content=dedicated_eoy&utm_campaign=whtdedicated_eoy1
WHT Special #4 看点:高配,IP足
Dual Intel Xeon E5-2620 – 24x 2.00GHz, 15MB Cache
32GB DDR3 ECC RAM * Upgrade to 64 GB for $64, 128 GB for $128
2TB SATA HDD
100% Uptime SLA
Choose from 7 Data Centers.
Order This! – Priced at $99/month, $0 Setup!
订购地址:https://www.ubiquityhosting.com/dedicated/order/token/985b755338a126157cbc44ffa90aed6e?utm_source=WHT&utm_medium=sponpost&utm_content=dedicated_eoy&utm_campaign=whtdedicated_eoy4
WHT Special #5  看点:便宜性能过得去
Intel Xeon Quad Core (x3430 series or faster)
4GB DDR3 ECC RAM
500GB SATA HDD
10TB Monthly Bandwidth (IN+OUT)
100 Mbps Public Network Uplink
/29 IPv4 Allocation
100% Uptime SLA
Order This! – Priced at $39/month, $0 Setup!
订购地址:https://www.ubiquityhosting.com/dedicated/order/token/8e93695797b6cb3338036e79145d979f?utm_source=WHT&utm_medium=sponpost&utm_content=dedicated_eoy&utm_campaign=whtdedicated_eoy5
WHT Special #6
Intel Xeon Dual Core (i3-540 series or faster)
2GB DDR3 ECC RAM
250GB SATA HDD
/29 IPv4 Allocation
100% Uptime SLA
Order This! – Priced at $25/month, $0 Setup!
订购地址:https://www.ubiquityhosting.com/dedicated/order/token/8e93695797b6cb3338036e79145d979f?utm_source=WHT&utm_medium=sponpost&utm_content=dedicated_eoy&utm_campaign=whtdedicated_eoy6
WHT Special #7
Intel Atom D525
4GB DDR3 ECC RAM
160GB SATA HDD
/29 IPv4 Allocation
100% Uptime SLA
Choose from Seattle, Los Angeles, Dallas, New Jersey, Atlanta
Order This! – Priced at $19/month, $0 Setup!
订购地址:https://www.ubiquityhosting.com/dedicated/order/token/8e93695797b6cb3338036e79145d979f?utm_source=WHT&utm_medium=sponpost&utm_content=dedicated_eoy&utm_campaign=whtdedicated_eoy7
数据中心:
Newark, NJ
Test IP: 69.147.224.122
Test Download Files: NJ –
  1. http://nyc.testfiles.ubiquityservers.com/1000mb.txt?utm_source=WHT&utm_medium=sponpost&utm_content=dedicated_eoy&utm_campaign=whtdedicated_eoyad
Atlanta, GA
Test IP: 173.234.140.58
Test Download Files: ATL –
  1. http://atl.testfiles.ubiquityservers.com/1000mb.txt?utm_source=WHT&utm_medium=sponpost&utm_content=dedicated_eoy&utm_campaign=whtdedicated_eoyad
Chicago, IL
Test IP: 174.34.172.51
Test Download Files: CHI –
  1. http://chi.testfiles.ubiquityservers.com/1000mb.txt?utm_source=WHT&utm_medium=sponpost&utm_content=dedicated_eoy&utm_campaign=whtdedicated_eoyad
Dallas, TX
Test IP: 174.34.178.210
Test Download Files: DAL –
  1. http://dal.testfiles.ubiquityservers.com/1000mb.txt?utm_source=WHT&utm_medium=sponpost&utm_content=dedicated_eoy&utm_campaign=whtdedicated_eoyad
Los Angeles, CA
Test IP: 108.62.74.18
Test Download Files: LAX –
  1. http://lax.testfiles.ubiquityservers.com/1000mb.txt?utm_source=WHT&utm_medium=sponpost&utm_content=dedicated_eoy&utm_campaign=whtdedicated_eoyad
Seattle, WA
Test IP: 108.62.62.26
Test Download Files: SEA –
  1. http://sea.testfiles.ubiquityservers.com/1000mb.txt?utm_source=WHT&utm_medium=sponpost&utm_content=dedicated_eoy&utm_campaign=whtdedicated_eoyad
Phoenix, AZ
Test IP: 23.19.63.34
Test Download Files: PHX –
  1. http://phx.testfiles.ubiquityservers.com/1000mb.txt?utm_source=WHT&utm_medium=sponpost&utm_content=dedicated_eoy&utm_campaign=whtdedicated_eoyad
发表于 2015-12-23 16:19:34 | 只看该作者
 楼主| 发表于 2015-12-23 16:21:05 | 只看该作者
whhuazi 发表于 2015-12-23 16:19
看起来很美。。。 顶下
我的入门VPS,貂狗VPS
发表于 2015-12-23 17:04:46 | 只看该作者
链接打开都是39刀的。有这家的vps,网络不太好
发表于 2015-12-23 17:07:47 来自手机 | 只看该作者
25刀居然内存比19刀的少,怎么想的
发表于 2015-12-23 17:37:42 来自手机 | 只看该作者
怎么比都不如PSYCHZ KRYPT
发表于 2015-12-23 17:43:02 | 只看该作者
具体看这个贴http://www.webhostingtalk.com/showthread.php?t=1538050
发表于 2015-12-23 17:57:46 | 只看该作者
3Q
发表于 2015-12-23 18:52:08 | 只看该作者
醉里耍大刀 发表于 2015-12-23 17:07
25刀居然内存比19刀的少,怎么想的
cpu好啊
发表于 2015-12-23 19:36:14 | 只看该作者
线路不好都是浮云。。
GMT+8, 2026-4-19 02:46 , Processed in 0.297090 second(s), 12 queries , Gzip On, MemCache On.
