查看: 8711|回复: 13
[疑问] CloudCore 简直是烂到爆炸
发表于 2015-12-21 10:22:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. # curl http://speedtest.singapore.linode.com/100MB-singapore.bin > /dev/null
  2.   % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
  3.                                  Dload  Upload   Total   Spent    Left  Speed
  4.   5  100M    5 5482k    0     0   255k      0  0:06:40  0:00:21  0:06:19  272k^C
  5. # curl http://speedtest.hkg02.softlayer.com/downloads/test100.zip > /dev/null
  6.   % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
  7.                                  Dload  Upload   Total   Spent    Left  Speed
  8. 32  100M   32 32.0M    0     0   354k      0  0:04:49  0:01:32  0:03:17  348k^C
  9. # curl http://speedtest.sng01.softlayer.com/downloads/test100.zip > /dev/null
  10.   % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
  11.                                  Dload  Upload   Total   Spent    Left  Speed
  12. 24  100M   24 24.2M    0     0   231k      0  0:07:23  0:01:47  0:05:36  191k^C
  13. # curl http://speedtest.tok02.softlayer.com/downloads/test100.zip > /dev/null
  14.   % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
  15.                                  Dload  Upload   Total   Spent    Left  Speed
  16. 100  100M  100  100M    0     0  5591k      0  0:00:18  0:00:18 --:--:-- 5329k
  17. # curl http://speedtest.sjc01.softlayer.com/downloads/test100.zip > /dev/null
  18.   % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
  19.                                  Dload  Upload   Total   Spent    Left  Speed
  20. 18  100M   18 18.2M    0     0   219k      0  0:07:47  0:01:25  0:06:22  194k^C
  21. # curl http://speedtest.sea01.softlayer.com/downloads/test100.zip > /dev/null
  22.   % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
  23.                                  Dload  Upload   Total   Spent    Left  Speed
  24. 16  100M   16 16.2M    0     0   183k      0  0:09:19  0:01:30  0:07:49  153k^C
这能用?
发表于 2015-12-21 11:08:41 | 只看该作者
发表于 2015-12-21 13:48:10 来自手机 | 只看该作者
LZ有钱**,我觉得这个算不错啊!sl自己的也才什么素质
发表于 2015-12-21 14:01:15 | 只看该作者
这都是包子的功劳啊
发表于 2015-12-21 14:13:04 来自手机 | 只看该作者
kddi没odn好
 楼主| 发表于 2015-12-21 18:59:25 | 只看该作者
CloudCore 并不贵啊
发表于 2015-12-21 19:00:06 | 只看该作者
drivel 发表于 2015-12-21 18:59
CloudCore 并不贵啊
你自己能买?走代购贵死了,我还不如撸一撸香港J
 楼主| 发表于 2015-12-21 19:00:29 | 只看该作者
hostvps 发表于 2015-12-21 14:01
这都是包子的功劳啊
一点都没关系
这个是从 CloudCore 到 Softlayer 各个数据中心的速度
 楼主| 发表于 2015-12-21 19:01:44 | 只看该作者
odn 似乎没有好的服务商吧
 楼主| 发表于 2015-12-21 19:02:53 | 只看该作者
可以的,嗯(严格讲不算自己)
所以倒不需要代购
GMT+8, 2026-4-24 02:39 , Processed in 0.063477 second(s), 10 queries , Gzip On, MemCache On.
