查看: 7849|回复: 32
看了@62900015的帖子后,哪能买纯CN2的鸡鸡
发表于 2015-11-26 22:28:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
感觉好难找啊
今天买的globalfrag的鸡鸡
8  202.97.50.145 (202.97.50.145)  63.911 ms  60.168 ms  59.954 ms
9  202.97.33.78 (202.97.33.78)  63.709 ms  65.143 ms  65.385 ms
10  202.97.35.106 (202.97.35.106)  70.209 ms  72.540 ms  73.517 ms
11  59.43.244.113 (59.43.244.113)  59.850 ms  60.197 ms  60.065 ms
12  59.43.182.137 (59.43.182.137)  194.641 ms *  200.216 ms
13  59.43.248.105 (59.43.248.105)  205.508 ms  205.347 ms  207.811 ms
14  218.30.48.46 (218.30.48.46)  204.668 ms  194.311 ms  194.174 ms
15  208.64.121.44 (208.64.121.44)  325.862 ms
    bl.gf.abr.globalfrag.com (208.64.121.18)  260.358 ms  286.717 ms
这是据说是CT云的,吊吊的CN2。
➜  ~  traceroute 66.102.252.97
traceroute to 66.102.252.97 (66.102.252.97), 64 hops max, 52 byte packets
1  192.168.0.1 (192.168.0.1)  1.728 ms  0.689 ms  0.602 ms
2  172.25.0.1 (172.25.0.1)  1.840 ms  2.500 ms  1.308 ms
3  121.31.121.189 (121.31.121.189)  1.345 ms  1.520 ms  1.440 ms
4  221.7.144.33 (221.7.144.33)  38.874 ms  24.984 ms  25.614 ms
5  219.158.23.121 (219.158.23.121)  52.175 ms  53.300 ms  51.757 ms
6  219.158.5.230 (219.158.5.230)  45.553 ms  45.547 ms  45.783 ms
7  219.158.40.174 (219.158.40.174)  45.733 ms  45.554 ms  46.337 ms
8  59.43.18.17 (59.43.18.17)  47.986 ms  48.176 ms  48.246 ms
9  59.43.246.166 (59.43.246.166)  51.552 ms  50.878 ms  50.835 ms
10  59.43.246.218 (59.43.246.218)  56.299 ms
    59.43.246.138 (59.43.246.138)  59.944 ms
    59.43.246.214 (59.43.246.214)  61.999 ms
11  59.43.182.141 (59.43.182.141)  186.349 ms *
    59.43.182.145 (59.43.182.145)  213.332 ms
12  59.43.248.105 (59.43.248.105)  194.675 ms *  195.600 ms
发表于 2015-11-26 22:29:53 来自手机 | 只看该作者
阿里云香港
发表于 2015-11-26 22:30:15 | 只看该作者
   globalfrag   100% 纯 cn2 线路 每个月加5刀 的   还有阿里云香港 b 区   双向 cn2 的
发表于 2015-11-26 22:31:31 | 只看该作者
 楼主| 发表于 2015-11-26 22:32:57 | 只看该作者
a1829 发表于 2015-11-26 22:30
globalfrag   100% 纯 cn2 线路 每个月加5刀 的   还有阿里云香港 b 区   双向 cn2 的    ...
我买了,globalfrag啊,但是不是纯cn2啊,走了202.97.* 后才到 59.43.*
发表于 2015-11-26 22:34:21 | 只看该作者
首先你自己要是CN2
  1. traceroute to 104.223.240.2 (104.223.240.2), 30 hops max, 60 byte packets
  2. 1 210.5.56.5 (210.5.56.5) [AS4809] 2.354 ms 2.479 ms 2.595 ms
  3. 2 118.85.209.42 (118.85.209.42) [AS4809] 27.679 ms 29.204 ms 27.795 ms
  4. 3 * * *
  5. 4 59.43.248.105 (59.43.248.105) [AS4809] 167.535 ms 167.588 ms 167.676 ms
  6. 5 218.30.48.46 (218.30.48.46) [*] 181.183 ms 179.817 ms 179.870 ms
  7. 6 * * *
  8. 7 ct.globalfrag.com (104.223.240.2) [AS46573] 179.533 ms !X 178.166 ms !X 179.614 ms !X
Google:电信,线路不对啊,我都来上海了……
  1. traceroute to 203.208.40.144 (203.208.40.144), 30 hops max, 60 byte packets
  2. 1 210.5.56.5 (210.5.56.5) [AS4809] 3.734 ms 12.307 ms 12.413 ms
  3. 2 118.85.209.42 (118.85.209.42) [AS4809] 27.944 ms 28.000 ms 29.957 ms
  4. 3 59.43.244.118 (59.43.244.118) [AS4809] 35.004 ms 35.092 ms 35.184 ms
  5. 4 202.97.35.97 (202.97.35.97) [AS4134] 31.705 ms 27.618 ms 31.766 ms
  6. 5 202.97.33.17 (202.97.33.17) [AS4134] 32.376 ms 32.467 ms 35.848 ms
  7. 6 101.95.120.105 (101.95.120.105) [AS4812] 32.069 ms 32.648 ms 33.776 ms
  8. 7 61.152.81.146 (61.152.81.146) [AS4812/AS4134] 32.244 ms 32.330 ms 32.410 ms
  9. 8 101.95.118.2 (101.95.118.2) [AS4812] 29.758 ms * *
  10. 9 203.208.62.26 (203.208.62.26) [AS24424] 28.261 ms 28.292 ms 30.718 ms
  11. 10 203.208.62.35 (203.208.62.35) [AS24424] 31.383 ms 29.489 ms 31.494 ms
  12. 11 203.208.40.144 (203.208.40.144) [AS24424] 30.161 ms 30.159 ms 30.005 ms
发表于 2015-11-26 22:36:18 | 只看该作者
发表于 2015-11-26 22:45:21 | 只看该作者
你自己就不是纯 cn2 的宽带啊 肯定有202.97的啊
看我的上海电信纯 cn2 企业宽带
发表于 2015-11-26 22:49:01 | 只看该作者
看我的上海电信纯 cn2 企业宽带
我不是纯CN2带宽,7楼的IP没有202.97
  1.   3     1 ms    <1 毫秒    1 ms  58.62.111.37
  2.   4     4 ms     3 ms     2 ms  59.42.179.69
  3.   5    24 ms     1 ms     1 ms  59.43.80.17
  4.   6     2 ms     1 ms     2 ms  59.43.247.82
  5.   7     2 ms     1 ms     2 ms  59.43.246.162
  6.   8     *        *       10 ms  59.43.183.106
  7.   9     7 ms     7 ms     *     59.43.248.194
  8. 10     5 ms     5 ms     5 ms  202.55.1.102
  9. 11     *        *        *     请求超时。
  10. 12     6 ms     6 ms     6 ms  118.193.144.3
发表于 2015-11-26 22:51:47 | 只看该作者
买了后 ,加了 5刀?
GMT+8, 2026-4-15 18:02 , Processed in 0.069647 second(s), 10 queries , Gzip On, MemCache On.
