查看: 3394|回复: 3
改了一下NC域名信息,这是要等60天才能获取转移码吗?
发表于 2015-10-29 15:58:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在NC的一个域名,想转出,修改了一下注册信息,获取转移码时提示:
  1. IMPORTANT: We strongly advise against providing your Authorization Code to ANYONE, including your host. Making it available to others is a massive security breach. If someone is asking to "authenticate" your domain ownership by asking for your Authorization Code, they may have questionable or negative intentions. Bear in mind that domains that are less than 60 days old are not eligible for transfer.
发表于 2015-10-30 10:33:35 | 只看该作者
好像不用啊,我上次转移的时候也修改了信息,直接可以转的。
发表于 2015-10-30 10:34:19 | 只看该作者
修改信息应该不用吧
发表于 2015-10-30 11:09:02 | 只看该作者
修改信息要等的
GMT+8, 2026-4-16 10:31 , Processed in 0.289439 second(s), 13 queries , Gzip On, MemCache On.
